586,069 active members*
3,750 visitors online*
    Dec 2008
    39
    Boring head help!!
    I am boring out cylinders on a outboard block. Have no problem centering and all that. My question is what RPM's can I run my boring head at??? I am running at 270 rpm with a .003 feed rate. finish is good plus I have to hone to finish. Problem is it is SLOW GO! What rpm should I run this head at? I have enclosed a pic of the boring bar I have, not actual but the same. R-8 spindle on a bridgeport machine with the off set tool. Thanks to all who reply!!!
    Oct 2003
    41
    Stay where you're at.
    Given the P.O.S. criterion style boring head with a large offset boring bar (held on by one screw:nono, and an r8 interface and likely not the tightest spindle bearings (quill, if you prefer), I think you've done well.
    You said "cylinders", plural. If you actually have some production quantity to do, I would be looking at a different machine and tooling. The imbalance of that boring head alone will severly limit your rpm. Feed rate is a function of rigidity and tool nose radius. You can feed faster with a larger radius, but the increased contact area may cause chatter.
    Cheers!
    Roy Solomon
    Dec 2008
    39
    no chatter what so ever. Roundness is under .0005. I was impressed, just very slow process. End result is good. I sped up to 650 rpms at .0015 feed rate and it was ok. Alot faster and still good finish. Thanks for the info!!!
  1. Boring Head
    By artin51 in forum MetalWork Discussion
    Last Post: 07-10-2008, 11:12 PM
  2. Chandler Duplex Boring Head
    By glmoore in forum Uncategorised MetalWorking Machines
    Last Post: 05-30-2008, 03:32 PM
  3. What Boring head should I go with for CNC?
    By SchurrPower in forum MetalWork Discussion
    Last Post: 03-10-2008, 11:07 PM
  4. Making a boring head
    By rigo430 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-20-2007, 04:08 PM
  5. What size boring head should I buy?
    By Kevin Harpham in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 02-09-2007, 11:55 PM
