586,089 active members*
3,756 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 0t pmc diagnostic parameters
Results 1 to 6 of 6
    Feb 2009
    12
    i have a okuma lathe with a fanuc 0t control. My problem is, my machine lost parameters due to low battery. Im able to manually input parameters but not able to input diagnostics such as timers. I dont have any of the parameters on disk just on paper. I normally turn on the control, activate e-stop,select mdi and even edit, turn pwe on, and attemp to input data but no luck. Am i missing something? i was able to input all the parameters including the 900's. all im missing is the diagnostics. thanks larry
    Oct 2008
    106
    I think you may need to go to OPERATOR'S PANEL page, their is a key switch need to turn on to change DGN
    Ahn Vuong
    Feb 2009
    12
    would you happen to know what data i need to change? ill check it out . thanks for your input.
    Oct 2008
    106
    See attachment what the Operator's panel page looks like
    Ahn Vuong
    Feb 2009
    12
    ill check my machine thanks for the help
    Mar 2009
    can it be parametr from femco durga? i have them all o-700 parametr and later all diagn.
    i have them and you can get them tommorrow..
    i have the same fanuck ot-c mainboard A20B-1003.....
    ver. soft 660-09 servo 9030-10..
    and trouble to send data to machine rs232 with cimco-edit.....but NO problem to save machines files on pc
    all the best
    jan
    sweden
  1. Replies: 11
    Last Post: 07-16-2022, 12:13 AM
  2. fanuc 5t parameters
    By karolg in forum Parametric Programing
    Last Post: 02-05-2009, 05:12 PM
  3. Replies: 1
    Last Post: 09-20-2008, 12:40 PM
  4. Fanuc 18-T DNC Parameters
    By JerryH in forum Fanuc
    Last Post: 12-14-2007, 02:15 AM
  5. Fanuc 3M Parameters
    By nastek in forum Fanuc
    Last Post: 12-29-2006, 02:35 PM
