586,121 active members*
2,997 visitors online*
Results 1 to 9 of 9
    Mar 2009
    9
    Control Software other then Mach3.
    What are some alternatives to Mach3 as far as control software goes?
    For DOS, there is TurboCNC, CNC Pro, and CNC Zeus.
    For Win98, there is KCAM.
    For Linux, there's EMC2.
    Then there are more expensive options.
    WinCNC, Indexer LPT, Camsoft.
    Jan 2006
    156
    There is Quickstep3 with the Pulse Pacer. Looks interesting and it is
    only $ 55.00. A 3 axis free controle software is available called
    Master cnc.
    May 2005
    101
    How about ARTCAM, Type3 and Enroute can they communicate directly with MACH3 machines ? If can how to work with them, kindly suggest.
    USBCNC looks quite interesting
    Andy
    Here's the link http://www.usbcnc.com/
    Mar 2009
    9
    Feedback, anyone? I need something reliable that will run with Windows XP
    What's wrong with mach3? There are well over 10,000 Mach3 users.
    May 2005
    101
    There are two steps. 1-Design a job in Coreldraw or Enroute or TYPE3 or etc. 2- Import in Mach3 and run the job. Now we would like to run the job from the designed software which should be compatible to send a job directly to the MACH3 compatible machines.
    270
    Quote Originally Posted by propmod View Post
    DeskCNC is a 32 bit Windows application that includes powerful cam along with the controller software. runs on XP,Vista, etc, but does not require fast hardware. Serial port, but also works with a USB to serial adaptor.
    Fred Smith - IMService
  1. witch CAD/CAM software with MACH3 ??
    By rontron in forum Mach Mill
    Last Post: 12-18-2009, 08:38 PM
  2. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
  3. probing software for Mach3
    By stirling in forum Digitizing and Laser Digitizing
    Last Post: 11-23-2007, 06:19 PM
  4. BP CNC S1 Speed control with Mach3?
    By Jonne in forum Bridgeport / Hardinge Mills
    Last Post: 06-18-2007, 08:31 PM
