586,103 active members*
3,314 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > DXF file crashes program
Results 1 to 8 of 8
    Apr 2004
    36
    I've been trying to import this file both as iges and dfx but BobCad won't run it and the program crashes version 19.6. I can't pocket or pick drill sequences. Any help?
    Attached Files Attached Files
    4826
    It's likely a garbage file. It has barely anything in it. What program are you using to create the file from?
    Mar 2004
    1806
    I opened it, and there was nothing there.
    Bubba
    Apr 2004
    36
    Sorry, I don't know why it didn't load, I'll try again.
    Mar 2004
    1806
    Paul,
    Loaded just fine and didn't crash in acad or in my cam (SheetCam), but it sure is made up of very tiny segments. Even the holes are done that way. I have played with it a little to use circles for the holes, and then made a couple of circles connected with lines at the quadrants and trimmed them out for the port holes and tried opening that and it works fine! I think the problem is that you have to small of segments for the program to be able to read it.
    Bubba
    PS: I also just noticed this might be something that was traced and there are several "jagged" lines on the exterior profile. I have to go to work now, but if you would like, I will clean the drawing up as I understand it and send it back if you would like? (obviously, I would check it out in my cam first :cheers:
    Jun 2003
    446
    Your file
    I downloaded the dxf file and opened it in V19.8 without problem. I take it that this file was originally a solid. With some simple editing I was then able to create profile and pocket toolpath for the part after verifying the X, Y and Z extents. If you have the IGES model, just open that and create toolpath. However, either way BobCAD did not have a problem with it. We did include some enhancements to the software since V19.6. Update your software.
    CNC Dude
    Mar 2004
    1806
    Paul,
    Well, I did as stated and found several open points etc. I have overlayed the major points and then ran it through my cam. It works. I have placed the salient shapes on seperate layers and left your original layer for comparison.
    Bubba
    Apr 2004
    36
    Guys, Thanks so much for the help. I've been through all the tutorial CDs but still need help. I appreciate it.
    Paul
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. Replies: 7
    Last Post: 01-18-2012, 03:52 PM
  3. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  4. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  5. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
