Well,
This project has been in the plans for over 2 years and finally I got around it. From solid works to fully functional in less than 6 weeks in spare time.
About the machine:
I wanted to use my existing square column HF 44991 but wanted larger and more rigid table. I have ordered replacement table for HF 33686 round column mill (table, cross slide, base, way guides - $260 shipped on a ship from China) that has table surface of 29 x 9 inches, and married the two.
Mechanics:
- 5/8" x 0.200" rolled ball screws on all axis
- Two ball nuts with adjustable preload (0-125lb) on each axis for backlash elimination
- Custom bearing block with preloaded twin angular contact bearings
- 480 oz-in steppers
- HobbyCNC 4-axis controller
- Toroidal 40VDC 20A power supply
I have successfully ran Mach 3 at 125ipm rapids using unipolar HobbyCNC controller configured for max output - 3A. Initial observations show that the hybrid is substantially more rigid. I was able to attain mirror finish in 6061 aluminum, faster cutting, and substantial reduction in noise. Following "hybridization", final table travel:
- X - 22in
- Y - 8.5in
- Z - 12in
I will install the Z axis for which all parts will be machined using 2D CNC operations with manual control over Z. I will also install an extension on the spindle head to make use of 8.5in of Y travel - stock unmodified 44991 results in 6.5in of travel due to removal of pivoting mechanism which took up over 2 inches of travel....limit switches are soon to follow, soft limits for now.
Cost of conversion if you were to start from scratch:
$499 - HF 44991 square column mill
$260 - HF 33686 table
$50 - separator plate
$40 - precision ground cast square
$210 - screws and 6 nuts
$50 - steel and aluminum
Total: $1,109
And about $5K worth of tools in your garage
Keep in mind that to get absolute backlash-free quiet and reliable movement, precision of bearing block is of paramount imprtance. So is the actual twin ball nut assembly which consists of preloader, retainer, fixator, etc...Cost of making anti-backlash twin ball nut assembly is approximately $45 versus $170 if you were to buy one.
Future things to come:
1. Pneumatic power draw bar
2. Automatic tool changer
3. Lathe attachment
4. And of course, videos!!
Engoy viewing this post!
A.S.
