586,103 active members*
3,366 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > New build! Gantry style based on Ahren's parts and 80/20 extrusion
Results 1 to 11 of 11
    Jan 2006
    141
    I've finally stopped looking and started putting together a CNC router. I've started a blog here for anyone that wants to watch the build progress/offer advice/heckle:
    http://cnc-for-not-free.blogspot.com/
    Thanks a bunch,
    Dennis
    :withstupi
    Jan 2006
    106
    It looks like your on your way! Good Luck with the machine and Ill be sure to check up on its progress in the future.
    Jan 2006
    141
    more progress, check it out on the blog.
    steel is expensive, at least from Alro! yikes.
    Jan 2006
    141
    more progress, comments/criticisms wanted.
    Sep 2007
    740
    Sorry you bought that router speed control. The one I have is junk. The speed controls built into routers are far superior.
    Oct 2008
    1147
    Looks like you are move along. NJ! All that 80/20 goodness. I really like Ahren's bearings. I just wish they were in my poor mans budget I did have a question about them. Is there any adjustment to them? Is there a way to get them to bite down on the flat steel or are they right on the money? I've wondered about that for a while.
    Apr 2007
    8082
    Quote Originally Posted by FandZ View Post
    Yes, one of the bearings on each end of the aluminum block is adjustable for the thickness of the required 1/4" thick rail. The two carriages on a given rail are held together by a connecting plate of your own design. The adjustment for the edge to edge rail clearance in your connecting plate can be provided with obround holes at one of the carriages or both carriages.
    Ahren's carriages are a bargain considering the amount of material and precision machining that goes into making them. The rails are the larger cost, depending on the width and lengths you need.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Aug 2008
    1166
    Looks nice. I've got a similar setup using Ahren's parts. From experience, I'd recommend greasing or oiling your thrust bearings during assembly. That detail slipped by me.
    Mar 2009
    80
    Looking great, keep up the good work.
    Northboy
    Feb 2004
    1086
    Groomden,
    Looking great! Looks like you're going to have a solid machine, and I love the dual drive. One note -- if you run out of T-nuts, save yourself some cash and get 5/16 carriage bolts and regular old hex nuts for a lot of your attachments (with the bolt riding upside down in the track). The square shoulder matches the t-slot almost perfectly and serves as an anti-rotation feature. The carriage bolts cost about $0.05 each, as opposed to $0.30 for t-nuts. I'd recommend this to attach your acme nuts. That being said, for some connections, the t-nuts are the only way to go.
    Best regards,
    Ahren
    www.cncrouterparts.com
    Feb 2004
    1086
    Deleted -- repeat post when cnczone went bonkers.
    Ahren
  1. First build! 3-Axis Gantry-style CNC
    By TheBakachan in forum DIY CNC Router Table Machines
    Last Post: 04-18-2009, 02:10 AM
  2. RFQ Z Axis Gantry style router
    By Jan-Roger in forum Employment Opportunity
    Last Post: 07-31-2006, 04:24 PM
  3. Overtable gantry style?
    By Dongle in forum Mechanical Calculations/Engineering Design
    Last Post: 03-09-2006, 04:57 PM
  4. Gibbs and a gantry style router
    By bgolash in forum GibbsCAM
    Last Post: 12-18-2004, 07:24 AM
