586,094 active members*
3,900 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Use a point for the start point of a profile.
    Dec 2007
    49
    I want pick an actual point for the start of a profile. Can this be done with V23?
    For instance, I have a profile and wish to start say x-.4 and y-.6 from the profile. How do I get it to start there?
    Any help is appreciated.
    P.S. I have been one of the complainers before, but V23 really seems to be working quite well for us now. Thank you BobCAD.
    David
    Apr 2007
    243
    All you need to do is draw your contour to start at that point.
    You have lead in and out options under profile, but you don't have to use them, just set them to vertical.
    Draw the profile you want to cut, including where you want the tool to start and end , then turn it into a contour. Then cut.
    The contour feature tells the software where the tool will start and end and what direction the cut will be.
    Dec 2007
    49
    Thank you. I will try this.
    * It worked Perfectly. Thank you again. Sometimes I get so caught up into how the software I used to use did things, that I forget to try a few new things and see what happens when I get stuck.
  1. Cutting start point
    By Mago in forum SheetCam
    Last Post: 05-28-2009, 02:52 PM
  2. Setting Start Point
    By Hellbringer in forum Mastercam
    Last Post: 11-24-2008, 05:29 PM
  3. re start point
    By woffler in forum BobCad-Cam
    Last Post: 11-06-2008, 02:56 AM
  4. Where to start ? point me in the right direction...
    By cruizer67 in forum DIY CNC Router Table Machines
    Last Post: 09-13-2005, 02:44 AM
  5. 2D Toolpath Start Point?
    By mlinder in forum OneCNC
    Last Post: 09-07-2003, 05:28 PM
