586,111 active members*
3,184 visitors online*
Results 1 to 8 of 8
    Apr 2007
    16
    Axis shift during machining
    I am using emc2 to control motenc lite controller. And using mastercam for creating nc data. the problem is that while machining x-axis shift to +ve side and z-axis take more depth than define. i explain it with an example " i make a rectangle of any size and make a program of conour on outside boundary. Define z total depth -1mm and depth of cut .01mm. During the machine running x shifts to +ve side and z ends with the depth more than -1mm. Anyone can help me out.
    Feb 2007
    514
    Is this a stepper system?
    Are you loosing steps?
    http://www.linuxcnc.org/docview/deve...tics.html#r1_3
    John
    Apr 2007
    16
    No these are contraves servo motors with 2500 ppr encoders.
    Apr 2007
    16
    i am attaching images of a job in which x-axis shifting to one side. It might give the clear picture
    Attached Files Attached Files
    Feb 2007
    514
    That's a pretty clear picture. I would have to guess some kind of hardware problem. Perhaps someone else has a better idea.
    John
    Apr 2007
    16
    John by the hardware i think you mean about ball srew, motor mounting, pulleys etc.
    Feb 2008
    644
    Quote Originally Posted by zeeshan.insight View Post
    Might also be x axis encoder losing or gaining counts (electrical noise?)
    Feb 2007
    514
    and like Peter said electrical too...
    John
  1. c axis work shift
    By Atlas_Too in forum Fanuc
    Last Post: 10-13-2008, 06:14 PM
  2. 5 axis machining.
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2008, 08:07 PM
  3. Setting Z axis with G92 work shift
    By venomgrrrl in forum Fanuc
    Last Post: 12-03-2007, 06:02 PM
  4. 5-Axis Machining
    By 5AxisMachining in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2005, 04:03 PM
  5. 4th axis machining
    By senor J. in forum Visual Mill
    Last Post: 10-22-2004, 09:10 PM
