I'm using 5 amp motors, so according to this formula i need 117k ohm resistors. I'm told they don't make such a thing. Is it possible that i can use a 120k ohm resistor without any issues?
Gecko 201's
Mark
Gecko 201's
Mark
Yes, you can use 120k without any problems. The difference is only ~2.5% which is within the 5% tollerance of standard resistors anyway - besides, it's not THAT critical. Good luck!
EDIT: If you're picky, grab a bunch of 5% 120k resistors (Brown Red Yellow Gold), measure each of them and pick the one closest to 117k.
Thank you. I do appreciate your quick response. Do you have any experience or knowledge with the c-11g bob. My next question involves wiring the bob to the speedmaster vfd. The first question will be easy. I purchased a small power supply to power the bob, however it has two outputs 5v and 12v. I'll need both one for the logic and the other for the analog to the vfd. My question is that this particular power supply shares a common ground, should i or should i not consider using this common ground for both, or should i just consider getting another power supply for the other voltage?
Mark
Without knowing more about your particullar VFD I would suggest NOT to use the 12V from that power supply if it shares its ground with the 5V.
Usually the VFD has an auxillary voltage that can be used to power external things like this. Usually it's 24V but a simple 7812 voltage regulator and two small capacitors would take care of it. (That's how I'm doing it on my C11 and my Siemens VFD).
Yes, my inverter provides 24V which I'm using to power the analog section of my C11 board (note that I don't have the C11G, just a plain C11 but I don't think the 0-10V output is any different).
So basically, instead of a separate 12V supply for the analog section the VFD supplies 24V to regulator which outputs 12V to the C11. This keeps everything separated.
Attached are two pages from my schematic. The first page shows the VFD, in the top middle section you can see the 24V and GND (0V) connections comming "out" of the VFD and going to the right, ending in small arrows.
These arrows points to the second page, which shows the C11 break-out-board. The 24V goes thru the 12V regulator and then feeds the analog section of the C11. The 0-10V signal leaves the break-out-board and returns to first page, entering the VFD on its AD1+ and AD1- connection. (Don't worry about the rest....)
Does that make sense?
/Henrik.
