Can somebody tell me where I can get a serial cable. I have an Okuma L-370 with a osp-e100l controller. I need a serial cable with db9 from the computer to a db25 on the machine. Thanks a lot for your help!
The problem is, the cable isn't a straight cable. The pin outs change. I would have been too easy to let you use a straight cable. Go figure...
GreyBar has Db9 & Db25 ends by there selves. If you have a greybar in your town go there and pick up what you need. You can wire it exactly how you need it wired. I'm sure you can get the cable for it to. And do a search for that type of cable in google I came up with a few
Try a standard cable with a null modem adapter. (Radio Shack)
Hey I just came across this website. I hope it helps!!
http://www.herbach.com/Merchant2/mer...tegory_Code=CC
