586,269 active members*
3,589 visitors online*
Thread: Bostomatic
    Mar 2008
    15
    Unhappy Bostomatic
    Hi All,
    I have an older Bostomatic 312 that is starting to give me problems. It has an SPCII control with a Ampex cpu . I believe the problems I am having now have to do with the power supply in the cpu. I find that it is putting out the +5V and -5V but not the 15V. I am getting the voltages from the back panel studs on the power supply and cpu.
    I was thinking of just replacing the power supply with new ones, a + and - 5v and a +15v but also see that there is an aux out put jack in the back of the old power supply that puts power into what I believe is the cpu board of the computer. I don't know what that voltage is supposed to be? I don't have a schematic of the cpu or the power supply?
    the model # of the Ampex CPU is 8CH532K , I believe the power supply # is 3502083. The power supply has no indications on it of what the output amps are for any of the voltages.
    Cans anyone out there Help.
    May 2009
    Maybe these will help
    Attached Files Attached Files
  1. Bostomatic 312 VFD questions
    By az7733 in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2008, 11:31 PM
  2. Bostomatic 300
    By mkruzel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2007, 01:16 PM
  3. Bostomatic 300
    By noid in forum Uncategorised MetalWorking Machines
    Last Post: 12-20-2005, 10:13 PM
  4. newbie with bostomatic 312
    By GBeaman in forum DNC Problems and Solutions
    Last Post: 11-07-2005, 04:34 PM
