586,485 active members*
2,052 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 2D Dimensioning in 3D?
Results 1 to 11 of 11
    Feb 2008
    123
    Ok, so I am going to try to explain this the best way that I know how. I hope that you guys can follow me.
    A lot of the time, I have to import 3D drawings from other software, usually Inventor and Solidworks. From these drawings, I have to build a fixture for holding. I have the hardest time dimensioning these 3D drawings in bobcad because the dimension feature wants to tell me the distances in real 3D space. But, what I really need, is the 2D dimension for the current view that I am looking at.
    As is many times the case, I may need to get the X and Y coordinates of a feature, but not neccessarily the Z at the moment. But when I try to dimension, it gives me a point to point distance in X, Y, and Z.
    If I havent explained this well enough, let me know and I will try better.
    Hope you guys can help me out.
    Thanks in advance
    Apr 2007
    243
    Few things you can do.
    Change your UCS so it's in the plane you need the dimension for This way the Z value won't get in the way.
    The other thing you can do is extract the wire frame and project it onto a surface in the X Y. This way you'll get ride of all the z values.
    If you are running a the v23 you now can dimension a point so that can be very useful as well.
    Dec 2008
    4548
    Hi Allen,
    Doesnt X-Ordinate or Y-Ordinate do this also? Or does it still give a 3d readout?
    Feb 2008
    123
    Ahh, thank you so much
    I knew it was something easy that I was overlooking
    Feb 2008
    123
    those both give 3d readouts
    Apr 2007
    243
    That just has to do with the way the numbers come out on the dimension if they go along the X axis or the Y axis. Nothing to do with the Z values.
    BobCAD is really only designed to dimension in a 2D plane.
    Pin Man, Do you want to post your file?
    Apr 2008
    78
    projecting wire frame to x-y
    how do you project a 3d wire frame onto a x-y surface...
    you can trim a line to screen wich the z depth does not matter.
    wouldnt it be easyto dimension screen so anything picked would be flat, no z depth.
    it is very iritating trying to get something dimensioned especially if there z's are not much different . then you dont realize your .002 off until later when you realize something is amuck.
    Apr 2007
    243
    Exclamation
    You use project on surface, it's found under the other menu.
    I agree you should be able to dimenstion to screen and that way it' all in the XY plane. This is something that would be useful, but you can always mesaure your part regarless of them being 3D or not.
    Use the verify feature the only thing is it doesn't print out those values.
    Mar 2009
    4
    I bought Omax Machiningjet 55100.
    I have to make different designs in the marble and granite(Madalions). Do you any body who assist me to getting cad/cam file of different designs. see attachment.
    BobyClick image for larger version.
Name:	Beige carpet.jpg
    Apr 2007
    243
    You know the carve wright machine would be perfect for what you are doing.
    http://www.carvewright.com/
    It comes with it's own software and it cheep!
    This machine is for wood
    Feb 2008
    123
    Quote Originally Posted by Allen123 View Post
    I ended up doing it the long way around, but basically I was trying to put some simple 2D dimension on this 3D model of some test equiptment that I designed. Here is the file.
    Attached Files Attached Files
  1. Dimensioning A Solid
    By TZ250 in forum BobCad-Cam
    Last Post: 02-13-2008, 02:12 PM
  2. Dimensioning and help files?
    By LorenzoNH in forum Uncategorised CAM Discussion
    Last Post: 04-27-2007, 08:33 PM
  3. dimensioning solids
    By sc_crasher in forum BobCad-Cam
    Last Post: 03-16-2006, 07:56 PM
  4. Auto dimensioning?
    By trubleshtr in forum Autodesk
    Last Post: 03-25-2005, 12:05 AM
  5. Dimensioning?
    By Ken_Shea in forum OneCNC
    Last Post: 07-09-2003, 02:51 PM
