Just thought people at CNC Zone would like to see the router designed and completed last spring for my senior design project at UNC Charlotte. It is a 3-axis CNC Router with a manual Z used for cutting foam and other soft/less dense materials. Motion supplied by ACME threaded rod, brass nuts, and thrust bearings. Power supplied by HobbyCNC 130 oz-in stepper motors controlled by HobbyCNC Pro Chopper Board. G-code is output using Artsoft Lazy-Cam and imported into Mach 3 which is used to control the stepper motors. I am actually hoping to sell the entire project and thought this was the best avenue to do so. If anyone is interested in purchasing the machine or has questions feel free to PM or e-mail me at [email protected] Any reasonable offer will be considered. You can download a detailed parts list and senior project paper which explains the entire process from start to finish.
http://www.zshare.net/download/57355226d09f5712/ - Parts List
http://www.zshare.net/download/573551966603a22c/ - Design Paper
Lots of photos in addition to the ones below can be found here: http://s191.photobucket.com/albums/z...ign%20Project/
If I could change one part of the design it would be the dremil clamp. When routing denser materials the clamp isn’t sturdy enough causing the tool to dig into the material being cut. All of the aluminum parts were cut out using our waterjet, www.aimsaws.com , and aluminum components machined myself at our shop in Hickory NC and UNC Charlotte Machine Shop. The project was a great learning experience since I have never designed anything this in depth before. A lot of information was absorbed by referring to this website.
Machine Specs:
2’ x 3’ Half Inch Aluminum Base
½” Aluminum machine components
Modern Linear V- Groove Rollers for X and Y axes
McMaster Carr Track Roller for Y axis
¾ - 1 ACME Threaded Rod with Brass Nuts for X, Y, and Z Axes
Channel UHMW for Z-axis
Thrust bearings for Y and Z axes
Hand crank for manual Z-axis
Hobby CNC Pro Chopper Driver Board Kit
Hobby CNC 130oz-in Stepper Motors for X and Y axes
12V @ 12.5A 150W POWERSUPPLY - MPJA
Artsoft Mach 3 Control Softrware via serial port - FREE
Artsoft LazyCam Software - FREE
