Originally Posted by
zax15uk
Rick,
EVA foam (Foamies) cuts quickly and easily, but as with other thermoplastics it will melt so shapes may not retain sharp corners or small detail.
It is not as bad as expanded foams though and you can get very acceptable results.
Depending on the application I either de-focus slightly (above the material) or use 2-passes at lower power to produce better results.
Zax.
Makes sense. Very good information. I think you have answered my questions. It sounds like it would work fine for my needs. Now I need to get my patterns together and find someone who can do some test cutting
Thanks!
Rick
steelandcopper.blogspot.com
wakingbearstudio.etsy.com
