Hello guys,
I have a hobbycnc pro board that is used to run my cnc router. I bought a Kyoto KD20C40AX SSR which is 3-32v dc input and 24-240v ac output.
My problem is I can not get it to switch the router on from my hobbycnc board. I am using pin 16 for the + input on the board and the - is connected to my ground connector on the board. I have attached a pdf file of the circuit. The SSR circuit is at the bottom of the page. By looking at the diagram, It showes a 2.2k resistor connected across both input pins. Is this correct? If anyone has a clue on how to wire up one of these SSRs, Please go through it step by step with me. I have only a few hairs left on my head and Id like to keep them There is something I am missing but I can not figure out what it is. I also made a crude drawing of the way I have it hooked now. See if I am missing something. If I need to add a externial DC power source please explain how to do this without killing my LPT. I believe I already killed port 1 and 17 because I touched the 24vdc pos side of my cooling power to the + on the SSR.
Oh well. Hope someone can help.
Thanks Steve
