Hi. I am using Mastercam V9.1 SP2 to mill out a handle out of plastic. I construct two 0.25 circles 1.0" from each other with a tangent arc or fillet with a 3.0" diameter between them. Each time I select create\arc or fillet\tangent\2 entities, type in 1.5 for the radius, select the two arcs I get many white circles around the two 0.25 circles. The 3.0" circle or fillet never gets constructed. I am not sure what I may be doing wrong, if anything. My guess is there is some sort of setting that will recognize what I want. Can anyone help? Thank you for your time.
