Originally Posted by
gaffa
Hi all, I am having a problem tuning my stepper motors. When
I jog any or all 3 they sound nice and smooth. The problem arises when I start a cycle in mach3, the x and y axis make a lot of chattering but still move. It's as if they are not tuned correctly but when I go back and jog them they sound great
I experienced the same condition you describe. My table is 5' X 10' I drew a series of lines in my CAD program. The first set I drew 4' long in the Y axis with .5" seperating the lines. then the same thing only 6' long for the X (long) axis. Then in Sheetcam I applied real world cut speeds to the lines. This allowed me to tune the drivers while the machine was actually running a "cut" file. Once I was satisfied at one speed I then changed the speed a bit & & re-run the program, to see if slight speed changes made a big differance in the sound/vibration.
It took a bit of time but I now have my steppers running at a nice smooth hum at all speeds. If you have an axis slaved to another you'll have to make slight changse to 1 then to the other. In my case the A or slaved axis made much more noise than the X & it was really hard to tell which it was till I got one of them quietened down.
If it works.....Don't fix it!
