Originally Posted by
DAB_Design
How many things can be ran off a single PC hdd connector using only the +5v and the ground?
Also, I checked the actual voltage coming from the PC and it checked more around 9v. Is that normal?
Check the label on your power supply it may give the current rating for the various voltages & current rating, typically the 5v is rated at 20 to 30 amps.
Unless you are checking from the wrong place your power supply should be maintaining 5v, NOT 9v.
Al
Albert E.
