586,094 active members*
3,912 visitors online*
Results 1 to 6 of 6
    15
    Drip feed mode for Mazak M32
    Does anybody use the Mazak M32 controller in "drip feed" mode? There is not much memory in the controller and we are using a cam system to produce G-code. I can successfully send "small" files into the memory of the controller to run them using the Tape I/O softkey. If I use the DNC option, it error's out with "DNC option not installed". Is there an optional board that has to be purchased from Mazak?
    Dec 2007
    300
    Smile
    All you need to do is put the control in "Tape" mode. (the key next to Memory) At that point the Work number in the upper right of the screen turns to asterisks and the control will wait for data to start coming from the RS232 port. First hit "Cycle Start" on the control then send on your computer and the M32 will take what it can and start running. When it needs more code it will call for it. Set your software to "wait for CNC". When the control sees the M30 it will stop asking for code.
    May 2008
    Mazak M32 comms
    Can you supply the cable details and pc protocol required to communicate with an M32 control as I'm having problems just sending ISO programs in and out, thats before I get onto drip feeding, thanks
    15
    MrMazak.....Thank you so much...It worked like a charm! The Mazak manual does not explain this.
    Jun 2010
    I have a vqc-15/40, m32. I also want to drip feed. what software are you using?
    15
    Using "Multi-DNC" software
  1. Drip feed mode with Fanuc OMA
    By visu in forum Fanuc
    Last Post: 02-07-2024, 11:35 PM
  2. Mazak eia drip feed help
    By mt92 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-16-2008, 01:24 PM
  3. Drip feed?
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-08-2008, 08:44 AM
  4. DYNA 2400 drip mode
    By JimHs in forum Benchtop Machines
    Last Post: 01-31-2008, 07:53 PM
  5. Drip feed mode for FANUC-6M
    By Digitech in forum DNC Problems and Solutions
    Last Post: 01-29-2008, 11:19 AM
