586,071 active members*
4,146 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > used cooking oil refinery oil recycling oil filtration oil purifier oil purification
Results 1 to 1 of 1
    Sep 2006
    8
    Smile used cooking oil refinery oil recycling oil filtration oil purifier oil purification
    This type machine is mainly used for purifying used cooking oil. It dewater, deodorize, and eliminate impurities highly effectively. According cooking oil nature, the used cooking oil include high water, more acid matter, much impurity and offensive odor. This machine adopt Plate Pressure system can separate the sundry goods and water from the oil quickly and effectively. Then superadd two primary filters and fine filter, it can remove impurities thoroughly. Next, the machine adopts highly vacuum system to dewater and deodorize. In addition, this machine use stainless steel filter element, it resist the acid in oil strongly. So, the used cooking oil was recyclyed by machine, it will become limpidity, golden color and fresh quality.
    Features
    1. Highly effective vacuum dewater, deodorize, and eliminate impurities system.
    2. It adopts Plate pressure system with the strong ability to filter the impurity, which can filter the particles and impurities completely.
    3. It has the back flush system, which can clear impurities automatically.
    4. We uses stainless steel filter element which has a good function in anti-corrosive. Especially, the precision of eliminates impurity is high and the service life is long. Also, it has a large volume for storing the impurities.
    5. The unique degas and dewater system: Using the 3D-Evaporation technical and thin film evaporation, which can separate the trace water, soluble water and gas from the oil quickly by the Multi-level water-oil separation technology.
    6. Hi-automatization operation, convenience, reliable, and safety
    Products list
    1. Insulating oil purifier
    1.1. Series ZY: Zhongneng vacuum insulation oil purifier
    1.2. Series ZY-A: Zhongneng Vacuum insulation oil automation purifier
    1.3. SeriesZY-B:Zhongneng Muti-Functional insualtionoil purifying machine (Regenration
    function)
    1.4. Series ZYD: Zhongneng Double-stage vacuum insulation oil purifier
    1.5. Series ZYD-A: Zhongneng double-stage vacuum insulation oil automation purifier
    1.6. Series ZYD-R: Zhongneng double-stage vacuum insulation oil regeneration purifier
    1.7. Series ZYD-M: Zhongneng Mobile Type Transformer Oil Purification Plant, Oil Recycling
    2. Turbine oil purifier
    2.1. Series TY: Zhongneng vacuum turbine oil purifier
    2.2. Series TY-R: Zhongneng vacuum turbine oil regeneration purifier
    2.3. Series TY-A: Zhongneng vacuum turbine oil automation purifier
    3.Lubricating oil purifier
    3.1. Series TYA: Zhongneng vacuum lubricating oil purifier
    3.2. Series TYA-R: Zhongneng vacuum lubricating oil regeneration purifier
    3.3. Series TYA-A : Zhongneng vacuum lubrication oil automation purifier
    4. Engine oil purifier
    Series LYE: Zhongneng vacuum engine oil purifier
    5. Diesel oil, gasoline oil and fuel oil purifier
    Series TYB: Zhongneng diesel oil, gasoline oil and fuel oil purifier
    6. Cooking oil purifier
    7. Transformer oil regeneration device
    Series BZ: Zhongneng BZ transformer oil regeneration device
    8. Oil purifier specially for Hydraulic oil and Lubricating oil
    9. PL Plate pressure oil purifier
    10. JL Portable oil purifying
    11. TYD Water oil separator, oil purifier machine
    12. Automatic oil tester
    Contact name: Tracy
    e-mail: [email protected] / [email protected]
    Mobile: 0086-13983479350
    MSN: [email protected]
    skype: tracyw888
    yahoo messenger: [email protected]
    Gmail (google talk) : [email protected]
    Phone: 86-23-86197079/68060921
    Fax: 86-23-86197078
    website: http://tracy127.diytrade.com / http://purifier68.en.ec21.com
    Your inquiries are highly welcome at any time, we are ready to make a response very soon.
  1. Replies: 0
    Last Post: 03-04-2009, 04:38 AM
  2. NSH VFD transformer Oil purification filtration machine
    By sinonsh22 in forum News Announcements
    Last Post: 12-14-2006, 09:07 AM
  3. Replies: 0
    Last Post: 10-10-2006, 09:19 AM
  4. Replies: 0
    Last Post: 10-10-2006, 09:17 AM
  5. ZN Oil Purification Oil Purifier Oil Recycling System
    By tracy127 in forum News Announcements
    Last Post: 10-10-2006, 09:00 AM
