586,103 active members*
3,514 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Hi, Everyone, I have a problem importing .stl files made in rhino...
    Jan 2009
    4
    HI,
    When importing a 3D model in Artcam pro I don't get the vector in the 2D view, so I can only generate the gcode for machining the entire "material", not just the vector of the 3d guitar top I want to machine...how can I solve that?
    Thank you and don't mind my english, I'm italian
    Nov 2006
    303
    Using the "relief preview" will give you a shape to trace.
    You may even be able to use the "Bit map to vector" function
    by messing with the colors. Don't have time at the moment.
    If it works I'll post it later. Hope this helps.
    Nov 2006
    303
    Try this instead. Import your STL file. Then save the .stl relief as a .rlf file. "Reset" your relief layer. After that "paste" the saved .rlf file. You'll have a vector outline of the profile. I would take a minute to smooth out the nodes. Pasted .rlf vectors are pretty jagged. Good luck
    Jan 2009
    4
    Thank you todd, I will try that later...
    This is the way I'd like to machine it...[ame="http://www.youtube.com/watch?v=3_qdZB9iGhU"]http://www.youtube.com/watch?v=3_qdZB9iGhU[/ame]
    just the top, not the whole piece of wood...probably the machining time will be the half...
  1. Importing from Rhino to Mach
    By gregrnel in forum Mach Mill
    Last Post: 03-05-2009, 06:41 AM
  2. importing control point curves from rhino
    By EvanB in forum BobCad-Cam
    Last Post: 06-24-2008, 01:07 PM
  3. Importing dwg.files
    By wsteve in forum Rhino 3D
    Last Post: 05-09-2007, 08:51 AM
  4. importing Mastercam art files in Rhino
    By sdantonio in forum Mastercam
    Last Post: 04-02-2007, 03:07 PM
