586,096 active members*
3,703 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Nov 2006
    63
    Thoughts on Tsugami
    Looking at the SS20 nice machine and nicely priced. Good, Bad, Ugly thoughts on Tsugami?
    Jan 2006
    4396
    They are well built, rigid, and durable. Set up is fairly straight forward.
    All around a good machine
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2009
    4
    the shop i work in just purchased a 1995 tsugami 25(D) does anyone have any sample programs that i could edit to use as a generic base program so i can get up and running.it uses fanuc otc controls.any help at all would be greatly appreciated.send any programming info or attached programs to [email protected]. thanks guy`s.
    Jan 2006
    4396
    Do you have the manuals?
    Toby D.
    Schwarzwald
    Mar 2009
    4
    I have one maual but the programming format is very vague and non-descriptive it only gives partial samples not an entire picture.
    Jan 2006
    4396
    Quote Originally Posted by paulbaird5150 View Post
    You must be talking about the Fanuc Manual. The Manual I'm talking about is written by Tsugami. It has detailed programs and specific diagrams related to your specific machine.
    The swiss I used is no longer made. It was a '94 with a Fanuc 1LE Control.
    Try calling Tsugami or this http://www.remsales.com/home/resources.html
    Toby D.
    Schwarzwald
    Apr 2009
    7
    We purchased a Tsugami BE20 V with a FMB Turbo 3-26 bar feeder about two years ago for in house parts. I had no prior experience with swiss style screw machines, just old cam driven brown & sharps but it was a quick machine to learn. With the Fanuc controls the programming is fairly straight forward, if you have written a program for any other mill or lathe you should be able to pick this up in a week or two. So far I have made over a million parts on this machine and have had only one serious crash. Not sure how it happened but we broke a cast housing were the bar feed mounts to the machine. Unfortunately this happened over the weekend when the machine was unattended so I am not sure what caused the crash. The cost of the crash about about $1000, not bad for a million parts so far. Overall this has been a great addition to our shop and I would recomend a Tsugami to anyone.
    Apr 2007
    30
    Tsugami is a great machine. I do recommened using straight oil in the machine. I had ones sub spindle lock up because of rust. Tsugami told me it's better to run straight oil. Although if you do run straight oil I would get a mistbuster 500.
    Apr 2009
    7
    cutting oil
    I use M22 light cutting oil from Jokish industries in our BE20. We have a rather large facility so smoke from the oil has not been a problem so far. If it gets to be a problem a mistbuster can solve it fast. I do recomend a chip spinner though, you will waste a lot of expensive oil if you do not spin the chips.
    Ed
    Apr 2009
    Tsugamis a good machine. One of the nicest characteristics for me is the fact that its not nearly as senstive to imperfect barstock as the Star. And the Star is even equipped with that piece of junk Rotary Magic guide bush....
    Aug 2006
    162
    i have the big brother the ss32 my observations:
    having the y axis on the sub is very convenit not only for spliting cycles but also centering tools
    if you use the radials on the sub you will more than likely lose the use of the the adjacent live/stationary holder
    the new tsugamis have air displacement on live tools making them water safe
    ive had one good crash (bar jammed in gb and slipped in main collet)and after indicating the holder back in machine runs fine(it broke a 3/8 spot drill sideways)
    one final note ss 20 is a convertible to gb-less a nice feature if you want to run extruded bar(i get away with it i just run the gb loose but i have had stock where it is so in consistent it can foul up
    over all a very nice freindly machine but it is a swiss and they are deffinetly diffrent
    Jan 2008
    21
    Question
    how do the Tsugami's compare to the Citizens? We run the A and L 20mm line, and I am happy with our citizens but I have recently been looking into the Tsugami's and I am interested in there machines, as they offer more live tooling on separate gangs for the same price point as an L20, I know there is alot of people who like either or, but im really looking for input from any persons who has worked with both the machines to know the ups and downs, thanks
    Feb 2007
    107
    LOOKING AT SAME MACHINE
    WE ARE LOOKING AT THE SAME MACHINE,,,,,,HAS ANYONE USED THE MACHINE WITH THE CHUCKER OPTION.
    PLEASE CALL ME AND LET'S TALK.
    DOUG
    651-653-0048 DAYS
    Mar 2008
    443
    I don't know if any of you looking for a "convertible" machine would be interested, but when I was at the Eastec show I found that Maier USA has one that is going for about $125K complete. I think it's called a ML Hybrid. I'm not sure about the size, but I believe it's 26mm machine.
    They use Fanuc controls, and have forced-air cooled spindles, cast polymer bases, and live tools that are the same ones used on Star machines. Looked like a good deal if you're a Fanuc-oriented user.
    Jan 2006
    4396
    Quote Originally Posted by PixMan View Post
    Thanks for the info. I'll have to pass this over a few desks
    Toby D.
    Schwarzwald
    Mar 2009
    100
    I'm starting up a S16 TSUGAMI from 1995 and it has a few working programs in it, test ran it 16 hours with no problems.. Once we get the programs loaded onto a computer, I can share them as a base program including synk both chucks to feed part past tool, cutoff and work on subspindle, part catcher etc...
    Jun 2008
    hi, i just start with this machine it has a fanuc 3/ia control, could you share some programs, i need samples to change my post processor, i'm using mastercam, my email is [email protected].
    Thank you
    Aug 2006
    162
    ss32 code
    heres some sample ops, honestly the start and end are always the same your just changing part lengths
    i have started an ss post for mastercam, but only the main side, it does have the ability to set the g300 and cutoff sync but no milling yet
    main
    O3011(PRESSURE INDICATOR)
    M91
    /M61
    M93012
    N10(START UP)
    M501
    G00G18G99T0/M08
    M11
    G300X-0.08Z1.256T0800
    G150Z-0.008
    M10
    G00X5.4331Z-0.04T0
    M502
    N20(FRONT FACING)
    M13S6000G00Z0.0T2525
    X0.705
    G99G01X-0.08F0.0028
    Z-0.04F0.08
    G41X0.545
    X0.705Z0.04F0.0028
    G40G00X5.4331W0.0T0
    GOTO1000
    N25(SLOTTING SAW)
    G28U0M8
    T0M5
    M8
    T0303
    M50
    G28H0.
    M82
    M23S3500
    G98
    G1X0Y0F236.
    G1Z.125F12.
    Y.290F20.
    Y-.290F20.
    Z-.06F40.
    Y0
    G28U0M25
    T0
    m51
    N45(SPOT CENTER)
    T1818M3S4000
    G0X0Y0
    G99G1Z.238F.002
    G4X.2
    Z-.04
    G28U0
    T0
    N100(CUT OFF BACK-SP)
    T0800
    M503
    M13S3200G00Z1.025T0808
    X0.705
    M504
    M56
    M53
    M505
    M506
    M20
    M98P707002
    G01X-0.08F0.0016
    M57
    M507
    N110(END OFF)
    M508
    M95
    /M92
    M96
    /M61
    G04U0.3
    M97
    M509
    M30
    N1000
    sub
    O3012(PRESSURE INDICATOR; .625 PICKUP COLLET)
    #500=0.0(1.0 SKIPS BACKWORK)
    N10(START UP)
    M501
    G00G18G98T0
    G310Z13.7795Y0.0T9900
    M502
    IF[#500EQ1.0]GOTO1000
    N30(.25 ENDMILL)
    M104S4000T3737
    Z0.04
    G99G83Z-.765F.006P2000
    G28W0.
    T0
    N20(#32 DRILL)
    T3333
    M123S2000
    G00Z0.04
    M104S5000
    G99G1Z-.060F.001
    G0Z.04
    G99G83Z-.935F0.0024P2000
    G80
    Z0.04F0.08
    G28W0
    T0
    N1000
    N60(WORK SEPARETOR)
    G00Z13.7795T0
    M105T9900
    M17
    G04U0.5
    G00Z13.7795T0
    M21
    M78
    G4U.5
    M79
    M18
    G04U0.5
    M28
    G28W0
    T0
    N90(CUT OFF BACK-SP)
    M503
    M21
    M105G00X0.0T9999
    M103S1500Z1.003
    M504
    M505
    G98G01Z.100F236.0
    M506
    M507
    N100(END OFF)
    M508
    G00Z13.7795Y0.0T0M105
    M509
    M30
    Oct 2011
    The Tsugami's are great machines. If you have an older Tsugami like an S16, S20, S25 and are interested in adding more tool positions I can help. We converted ours and now have 10 O/D turning positions. This greatly reduces your set-up time by allowing residential tooling. If interested contact me and we can discuss this.
    Jul 2006
    65
    Quote Originally Posted by ktkickinass View Post
    HAHAHAHA...I just had to laugh at that one...been there..
Page 1 of 2 12
  1. TMU Tsugami
    By Spaluz in forum CNC Swiss Screw Machines
    Last Post: 08-10-2013, 11:26 PM
  2. TMU Tsugami
    Last Post: 06-24-2013, 01:39 AM
  3. Tsugami s25
    By eameddie in forum CNC Swiss Screw Machines
    Last Post: 01-14-2013, 07:14 PM
  4. TSUGAMI BS 18 III
    By rahman161206 in forum CNC Swiss Screw Machines
    Last Post: 01-09-2013, 05:58 PM
  5. tsugami S25(D)
    By lukajt in forum CNC Swiss Screw Machines
    Last Post: 09-21-2009, 03:05 PM
