586,060 active members*
3,925 visitors online*
Results 1 to 7 of 7
    Feb 2009
    14
    Distorted engraving and cutting
    Our JMU3060 . Newlydraw 1.5
    makes strange pictures.
    sometimes it does this , sometimes not
    example:
    http://www.flickr.com/photos/albotrowa/3340164428/
    it also engraves and cuts double
    sometimes with , sometimes without distortion
    result:
    http://www.flickr.com/photos/albotrowa/3380299437/
    Design:
    http://www.flickr.com/photos/albotrowa/3381118582/
    What can that be ????
    Apr 2004
    305
    I would guess that it isn't the software. It looks to me that the machine is loosing steps. I believe that you can go into the preferences or settings and change the speed that you are cutting at. I think that if you slow it down a bit you can take care of that problem.
    Another thing that you can look into is the machine itself. With it turned off do all the axis move relatively smooth, with out binding? If not you may have an alignment issue or may need to clean the rails up a bit.
    Dec 2008
    1258
    I agree, it looks mechanical. The guitar image does appear to be caused by lost steps, either from mechanical binding or excess speed.
    The max speeds I use are 2 for 'cut' and 12 for engrave, any more and it will begin to lose steps.
    The other image is more difficult to determine a cause, but could be from the same issue or a loose mirror / lens. I would also confirm the beam is adjusted as close to center as possible at the travel extents (top left and bottom right - looking at the machine).
    Zax.
    Feb 2009
    14
    thanks for you comments !
    http://www.flickr.com/photos/albotrowa/3385177126/
    new results..
    Dec 2008
    1258
    Have you confirmed the beam is centered in the mirrors and the lens?
    It looks from this latest picture like the beam is being reflected off the edge and causing the distorted line / reflection. You also seem to lose power at the corner which could indicate the beam is no longer aligned. It is important that the beam is parallel to the axis, you need to check the alignment does not change as you move the head around the table.
    Zax.
    Feb 2009
    14
    Angry
    I did that just about 3 days ago...
    I 'll do it again.
    thanks
    Dec 2008
    1258
    Alignment should not change once set, unless a mirror mount is loose but it is simple to check.
    While you have the motors disconnected check if the axis movement is smooth and also ensure the Z-assembly does not have excess 'play'.
    Zax.
  1. Cutting and engraving
    By munich2007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-25-2007, 03:36 PM
  2. engraving not cutting with hypertherm
    By akylas in forum Waterjet General Topics
    Last Post: 12-22-2006, 12:20 AM
  3. Using laser for cutting and/or engraving
    By wilfredtak in forum RC Robotics and Autonomous Robots
    Last Post: 09-24-2005, 07:01 PM
  4. distorted hole
    By emergent in forum Visual Mill
    Last Post: 05-09-2005, 03:54 PM
