Just need some experienced advice if the following set up would work well:
1. 2.2kw spindle
Speed:24000rmp, Power:2.2Kw, Voltage:220V, Current 8A, Freq. 400Hz, 3Phase
2.JNEV-101-H1 VFD
1 HP 115 Volt -- USE AS A PHASE CONVERTER PLUS GET VARIABLE SPEED, Model JNEV-101-H1, Single Phase Input ONLY, Three Phase Output,Frequency Control Range 0 to 200Hz
is the 1HP Teco VFD with 0-200Hz frequency range and a 4amp supply enough to power the spindle which needs 8A, 400Hz frequency?
