586,058 active members*
4,290 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Lathe Programming from a Surface Model
Results 1 to 12 of 12
    Oct 2008
    50
    When I create a revolved base/boss(like a shaft or wheel) in Solidworks and I import into Surfcam and create > spline > cross section to get my geometry for lathe tool paths, why do I have to redraw some of the horizontal lines and always the radius's to get true toolpaths? I have also tried this with Create > Spline > Surface Boundry with just about the same results. Is there something that needs to be toggled on in Surfcam or do I need to do something different in Solidworks or Surfcam? I am running Vel. 4 and 09 Solidworks.
    DANGER ZONE - HARD HAT REQUIRED!!!!
    Jun 2007
    12
    I always seem to have to draw geometry when i do lathe parts in surfcamI go through the same process you described and end up still drawing geo.Surfcam dos'nt seem well suited to lathe
    RE: Lathe Programming from a Surface Model
    Try creating a Planar Surface through the middle of the part, then create your Surface Intersect Splines or Velocity4 has a new Surface Boundary Silhouette (Create | Spline | Surface Boundary)
    Darin
    Oct 2008
    50
    Quote Originally Posted by Darinbee View Post
    Darin
    I've done that did it, you still need to redraw your radius's and some lines. Draw something up in SW with radius and chamfers, bring it in to SC using create > spline > cross section and analyze all your splines you will see that some of them are not planer. You can get around this problem by changing your planar elements in your chain options to no. So is this a SW or SC problem?
    Oct 2006
    99
    My company has an add on that works with Solidworks that converts the part to a .dsn. this will give you a surface layer, a wireframe layer and a sketch layer. Not like when you upload a solid...not sure what it was called but it's out there.
    Jun 2009
    cross section your part in solid works through the plane which will best describe your part in a 2-d way , then open the file in surfcam, we do tons of lathe work and that is the method we have found to be the best.All of or jobs are done with the fixture fully modeled and the part in place but only represented in cross section
    Oct 2008
    50
    Quote Originally Posted by ChrisDoug View Post
    What is the process for that and how do you save it? When I tried it, the model came thru as whole not sectioned.
    Jun 2009
    Talking cut-extrude for lathe
    All I’ve been doing is selecting the plane in which I want to split the part and extrude cut half of it.Then you will want to save it with a modified name as to not change any of the properties of your whole model. We usually just add "cross-section" to the name as we usually have the whole model associated with milling fixtures or for compareing with our CMM data when parts are finished.Hope this helps
    Oct 2008
    50
    Problem Solved
    Just loaded Vel. 4 SP 1 and when you import a Solidworks sldprt or Parasolid you can also import the sketch geo. on a different layer and color. No mods. needed comes in clean and the radius are not splines. Thanks for all the help.
    Dec 2010
    Our old software is Surfcam 2000. How do I import a .sldprt file into it. I am brand new to this.
    Apr 2003
    637
    Not sure about this but I don’t think it has changed in 15 years. Select file, Open, a screen will open, then select the file type from the “Files of type” selection menu. Please note that Surfcam 2000 will not be able to open today’s current Solidworks files, only files that were current at the time your Surfcam 2000 was released. You will have to save the Solidworks file to a much earlier version (not sure what that was).
    Nov 2009
    93
    If you are using SurfCam 2000, then you are running 10 years behind.
    There's 2 things you can do to open SolidWorks files:
    1. Upgrade to SurfCam V5 2010
    or
    2. Import your file into SurfCam in a generic format like IGES (preferred) or SAT
    I would choose option 1, you are missing out on a whole decade of excellent innovations...
    Charlie
  1. Looking for a 3D model of a Bridgeport & Hardinge Lathe
    By NEATman in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2021, 07:30 PM
  2. Cnc Lathe Programming
    By millmonkey1 in forum Employment Opportunity
    Last Post: 02-04-2011, 01:17 PM
  3. Boxford Model A - My first lathe
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 02-03-2008, 12:32 PM
  4. CNC Lathe Tongil Model TNL-20 OT B
    By hien100881 in forum Australia, New Zealand Club House
    Last Post: 06-21-2006, 03:13 PM
  5. Surface finishing on a CNC lathe
    By fastturbovet in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2005, 05:23 PM
