586,069 active members*
3,410 visitors online*
IndustryArena Forum > CAM Software > Mastercam > right Angle Head help
Results 1 to 12 of 12
    Oct 2008
    45
    OK, this may sound like a dumb question! I need to know what i am doing wrong. I am using a right angle head for like the first time. It looks correct when i run it in master cam Even moves only in x and y, but the code don't look right it is still outputting in the wrong format. I should be drilling in X- but it still post in z-. I got to be missing something. I would love some help
    Maybe Its just looks wrong and i need to put the right G code in it to switch it in the machine. This is a Hass Vertical Mill.
    Apr 2003
    3578
    Did you setup a aggragated head tooling and setup the proper post for this?
    Cadcam
    Jan 2006
    4396
    Quote Originally Posted by inkydo69 View Post
    Well your first time is never for many of us. I never used one because most shops are too cheap to buy one.
    This will be an interesting thread.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2008
    3109
    cadcam is correct, your post must be modified, and the machine have an aggregate head added to it's configuration
    With the tool vertical, all interpolation is done in the G17 or XY plane with Z being the 3rd axis, in this plane arcs have I & J values to get their swing
    eg
    G0 X0. Y0. Z0.
    G17 G2 X0. Y-6. I3. J0. F10. ( Semi-circle from top to bottom )
    eg
    G0 X0 Y0. Z0.
    G17 G2 X0. Y-6. Z-1. I3. J0. F10. ( Semi-circle from top to bottom with Z going deeper by 1)
    But
    When you machine from the right side, all the interpolation is in the G19 or YZ plane and X is the 3rd axis, arcs have J & K values.
    eg
    G0 X0. Y0. Z0.
    G19 G3 Y0. Z-6. J0. K3. F10. ( Semi-circle from top to bottom )
    eg
    G0 X0. Y0. Z0.
    G19 G3 Y0. Z-6. X-1. J0. K3. F10. ( Semi-circle from top to bottom with X going deeper by 1)
    ( not sure if the following will work )( it may open it up for some other suggestions )
    You may be able to fudge it by using a ballnose ( WCS = top, cplane=top, tplane=right or something similar and manually modify the output )( you may have to turn off gouge checking in your ops ).
    Apr 2003
    3578
    Superman, has hit the correct thoughts to look for. I have done some preaty wild things with them in the past including full 3d work going bake ten years ago on version % of mastercam.
    I am going to share a video on this subject, this was put together by a friend from this board named Degmc. this is a very helpful and on this exact subject. this will be much easer then trying to write it in a post.
    Download and extract this a 51 meg file.
    http://www.mastercam-cadcam.com/video.zip
    Cadcam
    Jan 2006
    4396
    You guys are indeed Crafty
    Toby D.
    Schwarzwald
    Oct 2008
    45
    Quote Originally Posted by cadcam View Post
    Quote Originally Posted by tobyaxis View Post
    Quote Originally Posted by Superman View Post
    eg
    G0 X0. Y0. Z0.
    eg
    G0 X0 Y0. Z0.
    But
    eg
    G0 X0. Y0. Z0.
    eg
    G0 X0. Y0. Z0.
    OK i did change the config and added the aggregate head, but Super hit it on the nose! I had a bad feeling i would need to Change the post. I was wishing I could use the post I had configured for this shop, but looks like I get to do a new one for free this time ><. Oh I did try to fudge it didnt seem to work for me.
    If anyone has a hass post with this setup feel free to email me at [email protected] and thanks for the help.
    I am going to check out the video its down loading as I type. "Takes years at this shop I am consulting for lol"
    Oct 2008
    45
    Very Nice
    Just looked at the video very well done thanks!
    Apr 2003
    3578
    Here is a post to go with it. should be for X2 and higher
    Attached Files Attached Files
    Cadcam
    Here's the original article
    Hey cadcam, what days are you going to be at westec? I will be there Monday thru Wednesday
    Oct 2008
    45
    Thanks everyone!!!!
    Hope I can repay the favor.
    Oct 2008
    45
    Just so you all know worked very well!
    Cadcam the post worked very well i will send post a it back when i get time to edit to post for a hass gantry bed mill so everyone has it.
    Thanks again!
    Inky
  1. Right Angle Head Programming
    By ED209 in forum G-Code Programing
    Last Post: 09-29-2020, 05:11 AM
  2. Programing for Right Angle Head
    By bkobernus in forum Haas Mills
    Last Post: 04-27-2007, 11:31 PM
  3. Programming for angle head--G18/G19
    By Dave L in forum GibbsCAM
    Last Post: 07-21-2006, 04:33 AM
  4. Angle head in edgecam
    By smoregrava in forum EdgeCam
    Last Post: 07-06-2006, 08:00 PM
  5. Right angle head programming
    By Chris Baird in forum Visual Mill
    Last Post: 04-01-2006, 09:09 PM
