Would it be possible to laser cut a depth in eva foam without too much heat being generated?
So if you had a 20mm thick peice of foam, you could cut squares out to a depth of 16mm, (say 60x25mm) or would you have to really cut out that shape from a 16mm peice of foam.
Would lasering a area 60x25mm be a problem?
Cheers
