586,108 active members*
3,160 visitors online*
    Sep 2007
    17
    Question Mitsubishi DL MAZ Spindle Drive
    Looking for a replacement DC Spindle Drive for a Mitsubishi Meldas 500L series DL-MAZ with the following ratings:
    Type: DL-MAZ
    INPUT: 3 Phase 200V @ 50 Hz; 220/240 VAC @ 60Hz.
    Single Phase Control Circuit @ same voltage as above
    OUTPUT: 0-210 VDC @ 215A Max
    Field: 65VDC @ 20A max
    Doesn't have to be a DL-Maz, doesn't even have to be Mitsubishi (I'm an integrator and can pretty much adapt anything that's even close)
    If it helps motor specs are as follows:
    DC Super Line 30KW 210VDC @ 165A
    Model: Type: SDN-CFZ
    S/N: Z11783001
    Drive that is in my customer's machine at present will either cause Forward and Reverse Motor contactors to chatter or will just simply stop the firing circuits to the SCR's (uncontrolled stop). Don't really relish the thought of rebuilding this unit (although it is an alternative). Customer has already spent a ton of money on different repair approaches. Any help would be greatly appreciated.
    765
    This is a pretty old drive. I would suggest replacing it with either a Eurotherm or a Control Techniques (Quantum) drive. Both of these drives are pretty easy to integrate to these old DC motors.
    Scott
    Sep 2007
    17
    Thanks Scott, I will look into that.
    Regards;
    Norm
  1. mazak mitsubishi spindle drive
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-30-2014, 05:44 PM
  2. Mitsubishi FR-SGJ Spindle Drive
    By mikwest in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-29-2010, 10:03 PM
  3. MITSUBISHI SPINDLE DRIVE UNIT MDS-A-SPJ-75
    By chagin in forum MetalWork Discussion
    Last Post: 08-09-2008, 06:19 AM
  4. Mitsubishi MDS spdl. drive parametrization.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2007, 09:36 PM
  5. mitsubishi spindle servo drive
    By intermax in forum Servo Motors / Drives
    Last Post: 11-03-2006, 04:15 PM
