586,463 active members*
3,428 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How do I set up part zero and tool offsets on a CNC mill?
Results 1 to 14 of 14
    Mar 2009
    15
    Question How do I set up part zero and tool offsets on a CNC mill?
    Hi, I am new to CNC milling and I have a Fanuc 3M controlled AccuMill from the 80’s. We have a person coming in this weekend to train us on CNCing but I was wondering if there is any material on the Internet on how to do the following things.
    Set tool compensations & offsets.
    Set part zero & Machine Zero.
    The manuals and books we have primarily focus on programming and has little to no info about setting up the mill for running a job.
    If anyone can point me in the right direction I would greatly appreciate it.
    Thank You
    Adam
    Jul 2005
    12177
    What you are asking takes quite a lot of explaining; try doing a search here on CNCzone this type of thing has been discussed before.
    After you have had your training come back with specific questions otherwise you are likely to get buried with too much information.
    Mar 2009
    15
    The first question I have is...
    I am milling an Aluminum block that’s 6" x 6" with a 0.5" End Mill. The block is 1" deep and 0.5" of the block is sticking up from the vise.
    What part of the block do I place the End Mill on to set part zero for X & Y? In my CAD CAM software the left top front corner is part 0.
    Quote Originally Posted by Geof View Post
    Jul 2005
    12177
    You need to use the same reference point in the machine as you use for the drawing; in your case the top left front corner.
    This means you have to find the X and Y coordinates for this corner and enter them into the G54 work offset table. One way to get the coordinates is use an edge finder on the sides of the piece; your Trainer should be able to show how to use an edge finder.
    The tool offset is set to the top of the part. There are various ways to do this but the most direct is to bring the tool down to the part. I use paper between the tool and part to find out when I am close and this is good enough for non-critical work because paper is fairly consistent at two or three thou in thickness.
    Mar 2009
    15
    Thank you Geof.
    I do not have a edge finder at the moment (did not know they existed) what can I use untill I get one (ASAP)?
    Jul 2005
    12177
    Quote Originally Posted by AccuMillGuy View Post
    Thank you Geof.
    Put a piece of round stock in a toolholder and use this to detect the edge of your work again with a piece of paper between. Go carefully in jog mog of course set at 0.001" per click. You will feel the paper get gently gripped and if you go one more thou it will probably tear instead of pulling out of the gap.
    Now raise above the work piece and move further in the radius of your round stock and the spindle centerline is on the edge of the stock.
    You can enhance your accuracy by rotating the tool holder by hand when it has barely touched the paper and see if the paper gets tighter at a particular position of the spindle suggesting that your round stock is running out. Then you do the operation at the tight spot and the spot 180 degrees opposite and take the average.
    Mar 2009
    15
    Thank you. I do not know why I did not think of this... LOL
    I will do that on both X and Y side of the work peace, subtract the radius from those figures and that will be my work peace point 0.
    Thanks for wakening my dead brain cells ;-)
    Adam
    Jul 2005
    12177
    Thank you. I do not know why I did not think of this... LOL....Adam
    Because you probably fell into the trap I did when I first started with CNC; always trying think of the complicated way to do things. Then I realised these machines are not magic and I don't have to work to within a kazillionth of an inch all the time.
    When that is needed I take out my high quality paper.
    Mar 2009
    39
    you can do pretty much the same thing with the tool in the spindle and the spindle running, just use a long strip of paper to keep your hands clear of the cutter, bring it in slowly until the cutter Starts to tug the paper out of your hand... just a different technique.
    Nov 2008
    I'm not sure if this is considered shoddy practice or not, but I do the same as the other posters except I use .010" of shim stock that is kept handy, near the door on a magnet. Then just do the math to set "Z". Also, if the surface is to be face milled, I'll "scratch" the material with the spindle turning, back off the one or two thousandths and set "Z". Again, I'm not sure if these techniques that I use are considered "proper", but it works too.
    For "X" and "Y", I'll come in .010-.020" from each so that I get clean machined work, to keep saw marks and such from scrapping an otherwise good part.
    Jul 2005
    12177
    Quote Originally Posted by A_M_Roth View Post
    ....Also, if the surface is to be face milled, I'll "scratch" the material with the spindle turning, back off the one or two thousandths and set "Z". Again, I'm not sure if these techniques that I use are considered "proper", but it works too....
    Why worry if it is safe and it works.
    Here is a refinement on your 'scratch' technique that can be used on good surfaces. Get a nice fat felt tip pen and draw a spot larger than your cutter size. Bring your cutter down with the spindle turning in jog mode set at 0.0001" per increment of the jogwheel; stop when you see the cutter shaving off the ink.
    Nov 2008
    I've seen that done too, now that you bring it up.
    Jul 2005
    12177
    I did a variation on the felt pen ink idea when I was machining spheres in a Haas TL2.
    After finishing a sphere I inked it all over with black felt pen, changed the tool nose radius in the compensation by half a thou then ran the cycle again; the machine took off all the ink high spots. Then I went back to the original tool compensation and ran it and was left with a slightly mottled effect.
    Since then I have occasionally used ink to look at the blend between cuts when I flip parts in the lathe or mill.
    Apr 2009
    18
    Interesting, and good reading of different touch off techniques! I work on thick bulky +/- .06" plate stock. I have my trusty .19" D X3" pin clamped in a Jacobs chuck, tip ground to a point. Line up the edge with the point, set workpiece zero. For my closer tolerence stuff, I use a slick LED edgefinder.
  1. setting the tool data and the tool offsets
    By Michael82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2022, 03:10 AM
  2. enshu yuasa accu-mill am1547 tool offsets?
    By kustomkb in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2020, 12:44 PM
  3. Entering Tool Offsets in Mill
    By Geof in forum Haas Mills
    Last Post: 02-22-2011, 05:09 AM
  4. Tool offsets
    By plateroomred in forum CamSoft Products
    Last Post: 05-28-2005, 08:43 PM
  5. Tool Offsets
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-24-2005, 12:28 AM
