586,108 active members*
2,988 visitors online*
Results 1 to 5 of 5
    6855
    new prototyping software
    Worth a mention-
    Turn complex 3 or 4 axis jobs into parts in minutes with ProtoWizard. ProtoWizard is driven by 3D STL files generated by any of your favorite CAD systems. Simply import the STL file or files of your design, select a roughing and finishing tool, and in minutes you have the G Code file for any of the most popular CNC Milling machines.
    http://www.excaliburcnc.com/pwmain.html
    online demo- http://www.excaliburcnc.com/pwring_demo.html
    Feb 2007
    24
    Your links don't work. Sorry.
    Mar 2005
    214
    I use DeskProto, same idea, import an .stl generates g code really fast. Has all the features I need and great support by the guy that created it.
    Mar 2013
    Your both links are not working please check and provide the working links if possible. Otherwise you should explain more about this topic. I am interested in this topic.
    Apr 2004
    5737
    Protowizard is still around; here's a link to their site: http://www.protowizard.com/
    I prefer DeskProto's system for holding onto rings and other small parts that jewelers cut in wax. It doesn't have any moving parts, so there's no "slop factor"; you simply loosen a screw and fasten the pre-drilled wax blank in another position for further milling. It has an adaptor to work on Sherline's (and Taig's) popular 4" rotary table as well as Roland machines. Here's a link to further information about it: http://www.deskproto.com/products/123waxring.htm
    Andrew Werby
    www.computersculpture.com
  1. Engraving Software
    By The Wizard in forum Uncategorised CAM Discussion
    Last Post: 03-29-2005, 12:38 PM
  2. Software sales or "license transfers"
    By metlmunchr in forum BobCad-Cam
    Last Post: 07-05-2004, 10:47 PM
  3. ***One stop CNC software guide***
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-27-2004, 10:31 PM
  4. What software are you using?
    By BeerFizz in forum DIY CNC Router Table Machines
    Last Post: 12-06-2003, 10:15 PM
