586,094 active members*
3,999 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1991 fadal vmc20 comm with pc running XP
    Mar 2009
    hey Yall, New to the site here. I just bought the fadal VMC 20 single phase machine from the classified section of CNC ZONE, and having trouble with
    getting it to talk to my pc. I am not so savvy with the guts of communication
    and setup parameters. I am using (WELL TRYING TO USE) NCFADAL V1.3,
    Remember I am just a programmer w/Surfcam and a chip maker in my garage.
    Any help on getting my 1991 fadal vmc20 to talk to my pc running xp would be greatly appreciated. (i'm not even sure I have posted this correctly or in the proper location),but from what i've seen you guys here DO have all the answers.
    THX, PPWHAT
    Jul 2006
    67
    Fadal rs 232
    You will need a null modem cable.Set the comm settings for 7 data 2 start and one stop bit,even parity.A rs232 tester box comes in handy here.Make sure
    you are using the right comm port on your computer.Anyway,at the command prompt on the Fadal type ta,1 if you are not using the Fadal communications software,which used to be called Assist.If I remember correctly,with the Fadal software,you put the control in command mode and just send the program.
    Fadals are EASY to talk to.I have an old vmc 20 also,dont plan on taking any big cuts with it-and keep an eye on the x axis conduit,it breaks,coolant gets in there,and then it gets ugly!!!!
    Mar 2009
    Thanks JR, ive have been working on those parameters and will continue to do so today. There is something i'm missing so i'll recheck those parameters
    and go from there. I do have a copy of the older Fadal Assist dos prgm.
    thanks again and i'll check things out and get back to ya
    thx ppwhat
    Nov 2005
    41
    SDNC
    Say your running Surfcam? There is a DNC prgram called sdnc.
    The software comes with the surfcam and it works. I use it on my 1995 4020
    88hs. So you have another option.
    Jan 2004
    3154
    Windows Hyperterminal will send files to the control quite easily as well.
    www.integratedmechanical.ca
  1. Need a operators manual for a 1991 fadal Vmc 4020
    By New Fadal Owner in forum Fadal
    Last Post: 02-06-2009, 02:28 AM
  2. Help with 1991 VF1?
    By david bright in forum Haas Mills
    Last Post: 07-20-2007, 12:27 PM
  3. Issues with VMC20 using CIMCO Edit
    By SeriousMach1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2007, 10:48 PM
  4. Regrinding X Axis ways of '92 VMC20
    By MidfieldJake in forum Fadal
    Last Post: 08-04-2006, 04:29 PM
  5. 1991 Dynapath 10M Bridgeport
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 02-06-2006, 02:07 AM
