586,331 active members*
4,719 visitors online*
    Nov 2008
    522
    HighTechSystem's eccentric cam
    I have HighTechSystem'sMWHS
    I do like the table. Lots of holes and well-ground surfaces. The side plates with the 3 oval holes are good.
    So I've got 1/4" metal work here and trying to use the eccentric cam pieces. That's the bushings (as shown in the link) which are perfectly round and screws with the sides of the head ground round but eccentric so as you turn it, the bushing wobbles in circles and at some point is supposed to press against the side of the work. The eccentric-ground screwhead fits snugly inside the cam so the cam moves with the head.
    Now that I'm trying to use them, I'm not really sure how they're supposed to work. Is there supposed to be clamping from the top at all? (there's no top clamps in the kit) When I try to tighten up against the work by turning, I get this:
    The bushing will always be above the table, since if you tightened it against the table it won't be at the exact angle needed to press sideways against the stock.
    With the bushing not tightened flat against the table, when you tighten it by sideways pressure against the stock, the bushing wants to tilt slightly and it makes the stock float upwards off the table. Just by a few mils, being held securely just not against the table. I couldn't find a way around it really. I guess if I had an exact shim under the opposite side of each bushing to keep it from tilting, but it doesn't seem practical to pull this off.
    It's 1/4" bronze stock and only a couple of inches wide. I doubt the side compression is causing the stock to flex. It's just the cams leaning and popping it up.
    Am I doing it wrong? How is this supposed to work?
    270
    Quote Originally Posted by MechanoMan View Post
    That's about as good as it gets with a vise too. You can use top clamps if you need better flatness. If you don't adjust top clamps carefully, you can get the same kind of tilt.
    I have found that if the eccentric screws are turned all the way in, then backed off just enough to fit the part, that the work is held well enough for engraving and light machining in plastics and aluminum.
    Fred Smith - IMService
    http://www.imsrv.com
    Jul 2007
    1602
    Check out http://www.deepgroove1.com/videos.htm At the bottom right there is a video that shows how to use it.
    Nov 2008
    522
    Quote Originally Posted by rowbare View Post
    Ah I forgot about those videos.
    They actually have the mounting problem there IN the video. It's hard to see but one or more edges are lifted up off the table. I'm pretty sure I'm not just looking at stock beveled or rounded on bottom.
    Aug 2008
    hi all
    god bless u all
  1. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  2. An Eccentric Shaft
    By melt_fire in forum MetalWork Discussion
    Last Post: 02-18-2009, 05:39 AM
  3. An Eccentric Shaft
    Last Post: 02-17-2009, 12:23 PM
  4. Where to find offset or eccentric bushings?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 11-23-2008, 10:26 PM
  5. X2 drawbar rotating eccentric ...
    By binky72 in forum Benchtop Machines
    Last Post: 02-08-2008, 06:02 PM
