586,102 active members*
2,433 visitors online*
Thread: Citizen L25
    Jan 2006
    4
    Citizen L25
    On Citizen L25 with Meldas 500 series ( Mitsubishi CNC system) the memory got corrupted. Anybody help me out how to reinstall the CNC system
    Thanking you
    Sivadas
    Jan 2009
    27
    You should call Citizen or one of their local rep. Head office in Jersey # (201)818-0100.
    Mar 2008
    443
    Just saw this. Sorry for the late reply, but "citizencnc" is on the right track, you're goingto need factory support. Unfortunately citizencnc, the OP is in India, so the New Jersey HQ of Marubeni Citizen USA is a long way off for "appusivadas".
    When you say the "memory is corrupted", are you saying the whole control is one big error message? If that's the case, you'll first need to get the control a clean bill of health from your local Mitsubishi service provider. In days of old, all machines shipped with a complete list of the original parameter settings, and sometimes a copy of that (and the ladder diagram, which you may also need) in digital form. I don't know what materials you may have gotten with the machine in that regard, but anything will be a help.
    Best of luck to you.
    Jan 2006
    4
    Thank you for your reply. We are able to load all data's into the CNC system. But still problem with auto cycle and we contacted the local service provider of CITIZEN machine but it got failed. We are sending the CNC system to JAPAN for repair
    Jul 2009
    8
    Almost any corruption on the Mitsubishi 500 series NC system requires re-intalization to be done. Basically make the NC brain-dead, then reload parameters & SRAM, through the RS232 port after you reset the communication parameters. Then you re-load the ALL1 & ALL2 & macros. You can get the ALL1 & ALL2 parameters from another L425 with a simular software version or close serial numbers, the only thing that may be different will be the options on the machine & the gridshift values for the axes.
    Shadow
  1. Citizen CAV barfeeders
    By EdgeCrusher in forum CITIZEN Machines
    Last Post: 09-26-2017, 12:51 PM
  2. Citizen L20,L25
    By humbertocnc2007 in forum CNC Swiss Screw Machines
    Last Post: 02-18-2010, 01:17 PM
  3. pick off on citizen f12
    By cseely in forum CNC Swiss Screw Machines
    Last Post: 01-09-2008, 06:13 PM
  4. How to operate a Citizen FL-42
    By Twistr in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2006, 12:23 AM
  5. Milling with a Citizen C16
    By Koalas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2005, 08:22 AM
