Need help with G50
Ok, today for the first time, I tried to use G50 to find the center of a bored hole.
Initially, as I have never used it before, I tested with a separate ground wire on my probe.
It worked perfectly, however when I tried it on a fixed bore, it would go to the 12 o'clock position and stop, beep several times and quit.
Am I wrong, or should it go back to the original position first and then try the next trial ( 6 o'clock) and then proceed in the y direction or have I done something wrong.
I placed the probe in the approximate center, issued a G50 F2 and started the process.
Any thoughts will be appreciated.
Art
AKA Country Bubba (Older Than Dirt)
