Hi guys! I wanted to ask if there's anybody out there who can point me to the right direction on how to thread mill using mazatrol programming.. thanks in advance.
depends on the control vintage somewhat. you can only do I.D. type thread milling in mazatrol. O.D. would be manual unit or G code.
when setting up a point machining unit, key in "0" (numeric zero) in the field for surface finish designation. the softkeys show 1 through 9 and 0 is not part of the softkey set. this trick FORCES the tool path to always be in helix. if no 0 then mazatrol does a 360 clean up pass at the bottom with no helix! because it thinks youre using a ordinary end mill.
point machining- tap and point machining circle mill can both thread mill, eventually.
its tough to do a blind hole, too, mazatrol starts the mill DEEPER that your Z starting point, to allow ramping in. there may be a tpc that controls this?
i've seen some discussion on fusion and earlier that you have to name the tool as a floating tap? in tool data? matrix its prob best to name the tool as an endmill instead of a tap, too.
this is just my 2 cents. there is probably a few roads to get this. this is just what i remember off the top of my head.
jim
thanks jim! i'll try this first thing tomorrow morning..
