586,075 active members*
3,982 visitors online*
IndustryArena Forum > CAM Software > Mastercam > .stl file used for toolpath verification takes too long to load?
    Apr 2009
    I have received a casting drawing from my Customer. I saved a copy of the original file as a .STL file so that I could use it as a “stock” file for the tool path verification. However the .stl file is 65Mb and takes about 5 minutes to load. I am running Mastercam X3 MU1 on a dual core PC with 2GB Ram. It is insane to have to wait in excess of 5 minutes to see the tool path verification. What would you recommend?
    AJ
    Dec 2008
    3109
    STL Tolerance Adjustment ( file size )
    Seeing that you are only using it as a stock model
    On the original model, alter your settings to save the STL more coarse
    A tolerance value of 0.05mm gives very small facet surfaces. Try opening it up to say 0.20 or even more. You can merge the STL into the session to check accuracy, if required.
    On a Mcam SaveAs, the setting is in "System Config".
    If saving after verify, set the tolerance in "verify Options" before running verify.
    BTW: welcome to the forum
    Apr 2009
    Problem with loading .stl files
    Setting the .stl tolerance to 1.000 seems to work, but it takes a long time to load.
    I'll experiment a little more, but I may need a faster computer. Do you know what the recommendations are for running 26+Mb .stl files as "stock" files in Mastercam?
    Thanks for you help - much appreciated.
    Alan
    Vancouver, Canada
    Dec 2008
    3109
    Quicker method
    place the casting model ( solid ) on a seperate level
    pick this solid model as your stock model in the stock set-up
    you can also pick this solid when using verify
  1. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  2. file name too long
    By Claude Boudreau in forum Mach Software (ArtSoft software)
    Last Post: 11-06-2008, 03:42 AM
  3. how do i load xml file
    By bullethead67 in forum Mach Software (ArtSoft software)
    Last Post: 10-28-2008, 04:07 AM
  4. TL1 takes up the slack
    By gearman in forum Haas Lathes
    Last Post: 06-24-2007, 03:30 PM
