586,963 active members*
2,283 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tension & Compression tapping
Threaded View
    Apr 2009
    I have been using some old Kennametal, straight shank tapping holders. The shank is 20mm in diameter and the overall length is around 185mm long.
    I think the collets we use are the DA200 (J) type collets with the cut out in the bottom and square end. Can anyone confirm this collet as shown in the photo.
    Also does anyone know of a similar or the same tension and compression tapping holder that I can still purchase in the uk and collets to suit. Most of the tapping is for M3, M4, M5 and M6 ISO.
    I have sort of hit a brick wall with trying to locate information on these holders and collets and appreciate any help and info you can give me on them.
  1. Nikken Tension Compression Tap Holder
    By rbleth51 in forum CNC Tooling
    Last Post: 07-15-2008, 02:49 PM
  2. Tension Vs. Corriente
    By brutto in forum Spanish
    Last Post: 01-16-2008, 09:52 PM
  3. Hydraulic compression endmill holders
    By Geof in forum CNC Tooling
    Last Post: 12-09-2007, 03:09 AM
  4. Thread Milling using a Compression Tool holder
    By chase78 in forum G-Code Programing
    Last Post: 06-01-2007, 07:23 PM
  5. Tension/compression tap holders
    By Caprirs in forum MetalWork Discussion
    Last Post: 04-05-2007, 01:59 PM
