586,111 active members*
3,522 visitors online*
    Jan 2007
    435
    12vdc from 5vdc
    I have a board that requires a 5vdc 2a supply. I have a switching power supply for this. The board also requires a 12vdc supply at 10 milliamps. The two have to be isolated. Could I simply use this?
    http://www.alliedelec.com/Search/pro...0&SKU=800-0193
    It is a Cosel SUS1R50512C. It's described as Compact Multi-Purpose Isolated DC-DC converter.
    It would seem to be the smallest, cheapest solution.
    Mar 2007
    122
    Walwart
    Quote Originally Posted by TravisR100 View Post
    HI Travis,
    Have you considered pricing Walwarts at Wally World?
    Input 115 VAC, output 12 VDC @ 200-300 ma.
    Al
    Jan 2007
    435
    Yes, I've had several people suggest that. I prefer not to clutter my cabinet with a wall wart nor do I want to have to put an AC outlet in the cabinet.
    Jul 2003
    1754
    24221
    The one in your post look like it would do OK, the problem for you with the Digi-Key one is that it is not isolated.
    There are IC's that operate in a charge pump fashion to get it also, but most are not isolated either.
    Al.
    Albert E.
  1. where to get common 5vdc for g320?
    By Runner4404spd in forum Gecko Drives
    Last Post: 02-13-2007, 01:41 AM
  2. Gecko 210 5vdc, still confused
    By Gads in forum Gecko Drives
    Last Post: 03-24-2006, 03:58 PM
  3. 12vdc or not?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-18-2006, 05:13 AM
  4. Where to get +5vdc for my Gecko????
    By Apples in forum Gecko Drives
    Last Post: 09-05-2005, 12:45 AM
  5. 5vdc from paralell port, not enough???
    By thuffner3 in forum CNC Machine Related Electronics
    Last Post: 11-23-2004, 01:07 PM
