603,818 active members*
4,201 visitors online*
    Feb 2007
    25
    single axis control?
    I am in the process of building a 3 axis router, which is going well. I have another small rig to build; it's a pocket hole drilling setup. I am simply mounting 2 drills to a sliding platform and want the holes to be drilled at a consistent speed, so was thinking of driving it with a stepper motor. I already have a stepper, power supply and lead screw setup. I obviously don't want to run it off of a pc control. What is the best way of simply controlling a single action for a stepper? I would like the ability to adjust the stroke if needed (though it wont be very often). An ideal setup would be a foot pedal trigger, which tells the stepper to start the cycle, which will drill the two holes, then return to the original position. I have seen driver boards on Ebay, from China which are programmable with a small lcd screen. I don't know if that will be the right thing for this application. Any advise or a point in the right direction would be much appreciated.
    Thanks, Jay
    Jan 2006
    738
    You may be better off using small servo to drive this. You could use a DC supply to drive it down (servos try to maintain constant speed according to applied voltage) and stop with a limit switch or opto interupter. The limit could trigger a circuit to reverse the servo to pull back till another limit (upper limit) is reached resetting for the next cycle.
  1. Need a circuit to control a single stepper
    By wwendorf in forum CNC Machine Related Electronics
    Last Post: 03-10-2010, 04:30 PM
  2. Software for single axis manual control?
    By Corruptor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2008, 04:39 AM
  3. Single rail for Y axis?
    By jdholbrook in forum DIY CNC Router Table Machines
    Last Post: 04-18-2006, 01:29 PM
  4. need speed control for single ph motor
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 10-06-2004, 04:35 PM
