587,043 active members*
3,161 visitors online*
    Jan 2007
    83
    Connectors for CNC Mill Refit
    I am redoing a Bridgeport Prototrak Plus machine with new servos, encoders, controllers and Mach3. I want to use good connectors for the whole thing - so I plan to replace the existing connectors on my Pacific Scientific motors. Same for the position encoders (dual feedback to the controller). Anyway, what is a good line of reliable connectors that are reasonably priced? Some will need to be able to handle the high peak current of the servos. Suggestions?
    24223
    Look at the Amp-Tyco CPC line, they are the plastic version of the military MS connectors, but alot cheaper.
    http://catalog.tycoelectronics.com/c...eat/en/c/10574
    You should be able to get them from DigiKey, they come in all number of pin counts.
    Al.
    Albert E.
  1. Fagor 8025 / GE MarkCenturyONE refit problem
    By Odin M Yggdrasi in forum Controller & Computer Solutions
    Last Post: 12-19-2012, 10:59 AM
  2. Wire EDM refit control
    By Karl_T in forum CamSoft Products
    Last Post: 09-23-2010, 02:53 PM
  3. Starting a Test Refit
    By pauldkeeton in forum LinuxCNC (formerly EMC2)
    Last Post: 10-20-2007, 03:37 AM
  4. Setup Help, CNC refit
    By FBJR in forum MetalWork Discussion
    Last Post: 08-11-2007, 06:27 PM
  5. Bridgeport boss5 refit
    By paulsoncd1@juno in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2007, 12:46 AM
