Without knowing what post/setup sheet you're using, I'll just give you the code from mine...
Code:
if coolant = 1, " <td width=69 nowrap valign=top><p><font SIZE=-1>!", popnote, "</font></p></td>", e
It puts an "!" at the beginning of the Op Type:
Hope this helps, but I'm sure it won't because the chances that you are using the same setup sheet I made is, well... zero.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
