586,637 active members*
2,865 visitors online*
Results 1 to 20 of 30
    Feb 2006
    1072
    Distance rings?
    Does anyone have experience using 1/8" shaft carbide endmills with distance rings (i.e. PC board mills) with the Proxxon tool? If so, how repeatable is tool insertion, both tool-to-tool and successive inserts of a given tool?
    I realize that the Proxxon collet has a tapered OD , but finger-tightening it, even with the little lozenge wrench, should not be too variable.
    If the tools were repeatable (or maybe heat-shrunk aluminum rings...) I could populate a higher reach of the tool table with lengths for the little endmills (separate, of course, from the primary spindle tools).
    Thanks,
    Randy
    Mar 2008
    309
    Randy -
    You hinted several days ago that you would ask this question. I am very close to needing to make a PC board on my mill, and will be able to answer better after that. However, I have the surplus box o' carbide drills with rings on them, and all of the ones that I have played with are very tight on the shaft. I plan to do the same thing in the tool table if it works.
    Not having my Proxxon here at work, I don't remember if the collet sticks proud of the nut or not. I suspect, though, that even if it ends up indexing off of the nut itself it will be very repeatable.
    An emperical test would be easy to set up: Face an aluminum plate and then switch to the Proxxon. Install a mill with a ring into the Proxxon, and bump Z down and then move X or Y a little bit. When you make a faint mark, note the Z value. Replace the mill and try again. After a few trials, you should have the answer (remember, three is infinity for testing, especially if the numbers are within 0.0005" or so). That is a decent way to measure offsets for your tool table, too.
    You could do this with a touch plate, but I wonder about the endplay in the Proxxon bearings when it is running. That may be more than the placement error of the mill. Your locomotive drivers show that it is not much, but I still wonder if it isn't the larger error.
    Where do you get your mills? I get them from the dentist (for free), but they don't have rings on them. My hygenist knows to hand me a bag of them whenever I come in. I don't think they are carbide, either.
    Regards,
    - Just Gary
    Jan 2007
    93
    I have the upgraded primary spindle, and I've tried using some 2mm PCB at 5,000 rpm on 6061 and haven't had much luck. They tend to break at the top of the flutes after about 20 minutes of cutting. I wasn't sure if it was because of the low sfm or because the flutes were just too long. Could either of you post some of the feeds, speeds, doc and stepover that you've been using. I've been considering a HSS but didn't know if that would make a PCB endmill last any longer. Their flute length is far longer than what you would find on a endmill designed for metal but they are so inexpensive that they are cost effective even w/ the constant breakage.
    Feb 2006
    1072
    Just Gary, thanks for the feedback. The collet is proud of the nut when finger-tightened with the "lozenge wrench"), and also seems to be proud when just finger-tight, so that is encouraging. I just found a few PCB mills with distance rings I bought years ago at a model railroad show, so I can do some testing.
    I have been buying my tiny endmills from Bits & Bits, and they're not quite as free as your dentist-originated bits.
    I recently replaced the nose bearing on my Proxxon with a hybrid ceramic bearing from Proxxon World in Australia, which seems to have a better feel than the stock metal bearing did. It is a single bearing, but spring-loaded upwards against a stop on the spindle. With the light milling passes I'm hoping (and it seems so) that the mill doesn't pull down against the spring enough to deflect it (well, I realize that everything has deflection, but relatively not here...)
    thackman, the Machinist Mate software I use to calculate feeds and speeds (not being knowledgeable enough to do it in my head ) says for a 2mm 2-flute endmill in aluminum 29krpm and 16ipm feed. So at 5krpm the feed would be 2.75 ipm--I've had good success ratioing the feedrate from the rpm, assuming I'm using coolant. The .020" endmills I've been using want 76krpm and 10.7ipm in brass, and I'm not breaking any lately going 2.8ipm at the Proxxon's (assumed) top speed of 20k.
    herbert, the distance rings I'm talking about are the ones pressed onto the endmill itself. I know the term is used for various purposes (I've seen it used for lens spacer rings too). But your bearing distance rings (for preloaded pairs, right?) sound very nice. I'd like to hear about your experience doing that, if you don't mind telling.
    Randy
    Attached Thumbnails Attached Thumbnails proxxon-020endmill.jpg   distance_ring.jpg
    Mar 2008
    309
    Randy -
    Very nice photos.
    I'm thinking that indexing off the collet will work just fine, but I guess we really need to test it. My Proxxon doesn't sound anything like 20K RPM, by the way. My old Dremel has a much higher pitched whine. I don't have an optical tachometer, but by the sound, I don't think the Proxxon is even running 10K. Maybe it's just mine, and yours is faster.
    I'm working on whipping up one of those Porter-Cable router heads as an HSS, and putting the Proxxon on the bench. Having the 1/4" and 1/2" collets available for high-speed is just too nice to not head that direction.
    Speaking of Machinist's Mate (you mentioned it months ago when I was still waaaay to new to know to care), do you find that it gets the numbers right and that the Tormach can keep up? Or do you break tooling when using their numbers? I don't have any problem starting with 50% feed and working up, but do you trust what it tells you? I'm getting more interested in saving time now.
    Regards,
    - Just Gary
    Jul 2005
    302
    Red face
    Quote Originally Posted by zephyr9900 View Post
    J
    Randy
    Oh dear! Sorry, very embarrassing ...
    I was slumberous and did not read carefully ...
    At that - I use 1/16 endmills when cutting, 1/8 shank ...
    and I have many endmills and micro drills with distance rings you are speaking,
    but I dont use thoses systematised
    cheers,
    Herbert,
    now goes to bed
    :tired:
    Feb 2006
    1072
    Just Gary, I don't think my Proxxon is going that fast either, but I don't have any way to measure mine either.
    I know Machinist Mate is based on good solid numbers and when I use its recommendations I get good looking chips. The variable that is in my control (and for which MM gives no guidance because there are too many factors to consider--lenth of flute, length of cutter cantilevered from the holder, machine stiffness etc.) is depth of cut, and for that I tend to be conservative because going too far on that will snap cutters and I don't like that. I do know that I can be much more agressive with stub-length endmills (pretty much use their whole flute) than the extra-long cutters I usually use to machine narrow cavities as deep as I need to go.
    Randy
    Mar 2008
    309
    Randy -
    I have slowly learned the same thing about stub mills and lever arm on long mills. It's amazing the first time you actually see the difference between the two.
    I may give MM a try, because I'm ready for fast *and* good finish.
    On the distance rings topic, I'm cutting my first Proxxon parts today. I'll post them for fun later. The dental 0.030 mill is working great in brass at 5 IPM, 50% depth and 25% stepover. It starts to chatter above that, but I couldn't get it deeper into the collet, so it's pretty "long" right now.
    I'll play with the distance rings after I get these parts done.
    I may rig up a photodetector and watch a paint stripe on the Proxxon shaft. An oscilloscope will tell me the RPM.
    Regards,
    - Just Gary
    Jul 2005
    302
    Perhaps it is not what you need - I use 1/8" two flute carbide endmills when making ultra thin distance rings for angular contact bearings (for example) from adequate thickness bronze sheet (or Kapton, or Invar ... what ever) - 10...20 ... 30 ... pieces of sheet between two ca 2mm aluminium disk, then centre hole, then screwed on to round bar and using rotary table I cut OD and ID, RPM ca 30.000 and of course coolant.
    Veeeeeery nice distance rings!
    cheers,
    herbert
    Aug 2004
    2849
    Okay, stupid question...my friend is asking it.....
    He thought that the distance rings were to give an equal length from collet to the tip of the cutter?
    Thanks,
    Paul
    Mar 2008
    309
    ViperTX -
    Well, your friend is right, but in this case all we're looking for is repeatable placement of each cutter. Since we can use a tool table with Z offsets, each different cutter can have its own tool number and hence its own height.
    Once you set all of the tool heights in the table and write your program to use them, you simply replace the cutter, change the tool number in Mach 3 (which can be done in the program), and away you go!
    Regards,
    - Just Gary
    Feb 2006
    1072
    Just Gary is exactly right. I just shove a bit into the distance ring until it is just past the nose taper, to minimize the extension. I'm running out of collars to rob from the old PCB drills I have--I'll need to find a "local" fab shop so I can scrounge some more discards. Or a bag of 100 new ones from LPKF is $19 plus $8+ shipping.
    Randy
    Feb 2006
    1072
    Multi-tool operation with the Proxxon is pretty routine now. Just like using TTS in miniature. The only change lately is that I made a hoopy new toolrack to go along with my new TTS rack.
    I did break a .009" endmill (ex-101) the other day measuring it with my height gage while re-establishing my tooltable. Especially sad because I never broke it while actually milling...
    Randy
    Aug 2008
    45
    Randy
    Pardon my not knowing, KPKF ?
    Thanks! Larry O
    Randy
    Jul 2007
    1602
    Quote Originally Posted by Phishaholic View Post
    Randy
    Thanks! Larry O
    See post 12, there is a link to them.
  1. Fixing rings?
    By JayH1119 in forum CNC Tooling
    Last Post: 01-12-2009, 08:43 PM
  2. Fire Rings
    By millerrocks06 in forum News Announcements
    Last Post: 03-31-2007, 09:08 PM
  3. Depth setting rings
    By mgamber in forum Uncategorised MetalWorking Machines
    Last Post: 11-04-2005, 03:37 AM
  4. Ferrite rings?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 05-31-2005, 12:43 AM
  5. Making Custom O-Rings
    By NeoMoses in forum Welding Brazing Soldering Sealing
    Last Post: 05-13-2003, 04:07 PM
