586,062 active members*
4,291 visitors online*
    Apr 2009
    5
    Cool Mitsubishi control multiple problems
    Mitsubishi control on a Mazak VQC 20/40B. After 4 months of power down reinitialized the control but have a few issues.
    1) Now shows an "A" axis on screen
    2) When doing a tool layout the drum number changes to the program number plus one and all the tools dissapear.
    3) On tool data page when cursor is positioned on tool diameter input changes the length.
    Dec 2007
    300
    Smile
    By reinitialized you mean you followed the Mazak procedure? If you just turned on the machine and it is braindead there is more to it than reloading parameters. Do you have the procedure to reinitialize a braindead M2? (I do, if you need it let me know)After you follow the procedure you will then have to load a parameter backup or put them in from the parameter sheet.
    Apr 2009
    5
    If you mean turning off dip switch #2, turning machine on and off till parity lights go off then returning dip switch back on, that is what I tried. Then reloaded parameters from tape. This machine has a M1 control.
    Dec 2007
    300
    I have attached the Mazak procedure for M2 reinitializing. It should work for M1 also. Good luck with it.
    Attached Files Attached Files
    Dec 2006
    11
    f2 & f3 keys not powered
    I had done the reinitialization with the dip switches and now I cant access the hidden parametes , I can only access the normal parameters and my f2 &f3 keys are not powered (leds dont light up) whats the deal?
  1. Mitsubishi Meldas M3 Control?
    By Talisman in forum CNC Machine Related Electronics
    Last Post: 08-13-2019, 11:16 PM
  2. Mitsubishi Control problems on a Citizen
    By gearmachinist in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-23-2009, 07:06 PM
  3. KIA with Mitsubishi 520 Control
    By rikonen in forum Hyundai Kia
    Last Post: 03-28-2008, 02:39 PM
  4. Mitsubishi control help needed!
    By rogdog in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-09-2007, 07:54 AM
  5. Mitsubishi Control help
    By justin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-15-2005, 01:06 AM
