586,103 active members*
3,453 visitors online*
    Dec 2007
    85
    Hermle C40 Overtravel
    Hello, we have a c40 that is taking a nap as it overtravelled in the Z-axis and we can't figure out how to free it.
    Message
    MC LIMIT SWITCH Z+
    We are also getting a break test not performed message.
    Any help appreciated
    Jun 2008
    1511
    Look to see if you have a OT bypass or release button. You usually have to hold the button in and move the axis off the limit switch using the hand wheel if you have one. You should then be able to rest the alarm.
    You also may have a swith that is stuck.
    Stevo
    There are no limit switches just hit the CE key.
    As for the "break test" there is a soft key in manual mode that you have to hit periodically.
    Dec 2007
    85
    Got it
    Thanks for all the help but this issue required unpublished information from Hermle.
    We had to increase the hard-coded allowable travel on the machine, wind it down a bit and set the allowable travel back to it's default.
    This info is not given out as people have tried to artificially increase their travel by changing these numbers and have caused damage.
    cheers
    Sean
    Jul 2008
    26
    this thread is old.. but the C40U is a fine machine. Fast and holds tenthousandths all day. My former employer had 2 of them.
    MoRdAnTlY [Mr. Wolf '91 - '10]
  1. Does any one have a Hermle UWF 1000
    By Repair_man in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-07-2014, 03:52 AM
  2. Hermle spindle drive
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2008, 03:37 PM
  3. Hermle UWF700
    By ariesdenmark in forum MetalWork Discussion
    Last Post: 11-22-2007, 12:50 PM
  4. Does any one have a Hermle UWF 1000
    By Repair_man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2007, 01:22 AM
  5. 5 axis post for a Hermle C 800 U
    By swisssat in forum Post Processors for MC
    Last Post: 09-06-2007, 02:53 AM
