Code:
Connect YELLOW and BROWN cable pins
Press any key to start test
Scanning devices...Ok
1 USB cables found.
Opening Device...Ok
Configuring cable:
Bit bang mode...Ok
Timeouts...Ok
Latency...Ok
Baudrate...Ok
Cable IO test
Sending data...Ok
Reading data...Ok
Comparing data...
Error
Possible problem here!
Test FAILED
I have used this cable just two week ago and it worked fine
VSD-XE was OK for playing around but it turned out it has too many sharp ends and little problems for production use. When customer hits the problem you don't even know where to start troubleshooting so the whole system has to be sent back and forth... It's a shame since it's a great product on paper...
