Originally Posted by
Harmeet
Kulveer and adjen
There is no other write protection other the the key switch...
1) First input the 900 option parameters manually..
2) Off the machine for 2-3 seconds and turn it ON again..
3) Then input all the other parameters according to the list..
4) Repeat step 2..
5) Now all the axis should move..
6) For the turret and in some cases for spindle and chuck operation, there is Diagnostics data 300 to 550 which consist of timers, counters, Data and keep Relays of the machine...
7) If you dont have the diagnostics data then u have to check the same one by one in the ladder diagram and put it manualy...
Timers
1) 300
2) 305
3) 310
like this you have to enter the timer data after leaving five like first 300 and then 305..
You can simply put some value in those data.... and then try to run the machine.
others are depending on the machine such as keep Relay and Data registors..
