586,667 active members*
3,576 visitors online*
IndustryArena Forum > CAD Software > Solidworks > from solid to surface
    Nov 2007
    79
    hi gents
    i make my design in a solid works 2007 and then convert the file to mc 9 , then i creat surface from solid in mc 9 ,i tried to convert the solids to a surface in solid works but i couldn't figur it out , i just know how to delet a face of a solid to get the surface , my question is are there any command in solid works that changes the solid to a surface with out deleting it's face?????
    any answer will be appreciated
    thnx
    Aug 2007
    95
    You could save as an IGES file then open in Mastercam and it would be in surfaces.
    Nov 2007
    79
    i know how to make iges to convert to surface in mc9 ,,,, my question is how can i convert solid to surface in solid works??????
    thnx
    Sep 2005
    1660
    The easiest way is to use the surface offset function in SW. Simple select the surface of the solid that you'd like to change into a surface. Select the offset surface function and set the offset to zero.. voila'
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jul 2007
    9
    Another useful tip when using the offset surface function is to use the "Select Tangency" command available when you right click on a face. This could save you alot of time by not having to select individual surfaces.
  1. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
  2. solid surface cnc choice
    By EvanB in forum Commercial CNC Wood Routers
    Last Post: 04-08-2007, 03:12 PM
  3. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
