586,106 active members*
3,048 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need help: Identify ball screw/ ball nut
    84
    I have a Webb mill that the plastic oil lines rotted away on. No oil going to the ways or ball nuts.... I managed to get it apart, but damaged 2 of the plastic ball returns in the nut. It is a Prototrak Trak cnc conversion. The ball nut has 6 circuts (6 little plastic returns) and is marked PR-723 P/N-14972-16. Any ideas of who made this? Parts?? A local ball screw place (Barnes) quoted a MINIMUM OF 350.00!!!!to repair. All I need is 2 of the little plastic pieces and I can get it back running! Thanks for helpin' Rick
    Jan 2006
    I'm having the same issue, did you ever figure out how to repair it?
  1. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  2. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
