586,357 active members*
3,457 visitors online*
    Apr 2009
    Thumbs up mach 3 problem
    I am new to the cnc plasma scene . I just built a 4x8 CamCutcnc table.The software to run the table is mach 3.The problem i am having is when i bring a dxf file it cuts the outside first .Any help would be much appreciated thanks.
    Jul 2007
    887
    Not a Mach3 problem.... Mach3 cuts the part in the order the G-code tells it to. You have to open the .dxf in a CAM-program such as LazyCAM, SheetCAM, CamBam etc. You use the CAM-program to select what and how (which contours, in what order, what direction, what feedrate and so on) to cut and it (the CAM program) then generates the G-code that Mach3 runs.
    HTH
    /Henrik.
  1. little problem with mach or something else?
    By ataxy in forum Mach Mill
    Last Post: 01-30-2008, 02:27 PM
  2. Help! anybody have this problem w/ Mach 3?
    By sconklin in forum Mach Mill
    Last Post: 09-18-2007, 12:54 PM
  3. Anybody had this problem in Mach 3?
    By pointcloud in forum Mach Mill
    Last Post: 07-13-2007, 02:09 PM
  4. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
  5. mach 2 problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2005, 09:12 PM
