586,071 active members*
3,567 visitors online*
    Apr 2004
    38
    Dyna 4400 pst help
    I am trying to get a post for the Dyna 4400 mill to not output x and y values that are the same as the previous block. I have tried everything in the plin post line but I cannot get the state to change. The machine does not use standard G&M codes so it is not a normal post. The code that the mill uses is really awful but I need to get this post working so that I can reduce my file sizes. Anyone want a stab at this? Any help would be greatly appreciated as I need to cut parts as soon as I can. This post was one of the posts in the Mastercam V9 library.
    Jim Walthall
    Mar 2004
    21
    In the plin block, you should have something like the following
    pxout, pyout, pzout, pfr, e
    If is like this,
    pfxout, pfyout, pfzout, pfr, e
    then it is being forced out. change to first sample. If you need more help
    email me your post.
    [email protected]
    Apr 2004
    38
    Thanks, Masspfei for the responce. My troubles went away on Monday when the control bit the big one. I am now in the process of a retrofit then I will be able to get back to the real world of standard G& M codes. But again thanks for the advice I will check the post and try it just to see . It is allways good to learn on posts.
    Cheers
    Jim Walthall
    May 2003
    64
    Dyna 4400
    I heard your controls bit the dust. If you retorfitted it how did you take care of the ATC? I may have a chance to pick up one of the. The guy has two both in good mechanical condition. I offered to retorfit one free for him giving me the other. He said yes
    Dan Mauch
    Camtronics Inc
    www.camtronics-cnc.com
    Dan Mauch
    Camtronics Inc
    [email protected]
    www.seanet.com/~dmauch
    May 2010
    Hi, I use Dyna myte4400H. I want to transfer the program from the pc. we bring the receiver state machine, such as the error text is on the E04. contribute to the solution I'll be glad you provide.
    Thank you.
    Hasan - Istanbul
  1. Dyna Mechtronics cnc Knee Mill need help with control
    By wisp in forum Knee Vertical Mills
    Last Post: 01-08-2021, 05:20 PM
  2. Dyna Mini CNC
    By topazx2 in forum Benchtop Machines
    Last Post: 04-30-2013, 12:56 AM
  3. Dyna Myte 4400 (or other model) owners/users
    By mmedina in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2010, 04:22 PM
  4. Ebay# 3855421933, FRAUD DYNA MYTE MILL
    By davidponte in forum Community Club House
    Last Post: 07-01-2005, 02:09 PM
  5. Dynamectronics 4400
    By Ernie in forum Uncategorised CAM Discussion
    Last Post: 08-08-2003, 09:05 AM
